Cadmandu 67 #1 Posted April 17, 2019 Hi all How do I remove the strainer screen under my tank beside the the shut off? thanks Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted April 17, 2019 If you are talking about the screen part in the tank and don't have long needle nose pliers then you will have to pull the fuel shutoff out.It takes some effort but it will pull out of the rubber grommit Share this post Link to post Share on other sites
Cadmandu 67 #3 Posted April 17, 2019 Thanks for the reply. Do you mean that it just pulls out why wouldn't leak? Share this post Link to post Share on other sites
The Tuul Crib 7,339 #4 Posted April 17, 2019 (edited) There is no screen on the shut off valve that I know of Edited April 17, 2019 by The Tool Crib Share this post Link to post Share on other sites
richmondred01 2,307 #5 Posted April 17, 2019 (edited) Some of the valves do indeed have screens. The screens can’t be removed. Buy a new valve and grommet. They are cheap Edited April 17, 2019 by richmondred01 3 2 Share this post Link to post Share on other sites
Cadmandu 67 #6 Posted April 17, 2019 Great picture where can I buy this kit? Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #7 Posted April 17, 2019 3 minutes ago, Cadmandu said: Great picture where can I buy this kit? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302939588596 1 Share this post Link to post Share on other sites
richmondred01 2,307 #8 Posted April 17, 2019 eBay search for Toro Wheelhorse 104048, 46-6560 or 104047 1 Share this post Link to post Share on other sites
Cadmandu 67 #9 Posted April 17, 2019 It's unbelievable how much you guys know. Thus forum is so helpful and really needed by many. I purchased the one with the filter screen item number 291551135450 3 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #10 Posted April 17, 2019 Personally I would rather have an in line filter rather than this screen. just my Share this post Link to post Share on other sites
Cadmandu 67 #11 Posted April 17, 2019 Me too I have new inline also. I'm just wondering about what is in my tank?lf I have a dirty screen I want to replace it. What do I have to do to send a pic mine are too big Share this post Link to post Share on other sites
richmondred01 2,307 #12 Posted April 17, 2019 I use both. No restrictions 1 Share this post Link to post Share on other sites
JAinVA 4,638 #13 Posted April 17, 2019 When you get the replacement install the grommet first.Apply a little grease on the shut off below the screen area and install with a twisting motion. 2 Share this post Link to post Share on other sites
Cadmandu 67 #14 Posted April 17, 2019 I'm actually fighting a slow startup only when cold. I'm hoping to find some simple solution. Can you take out the mechanical fuel pump and clean it with any luck. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #15 Posted April 17, 2019 11 minutes ago, Cadmandu said: I'm just wondering about what is in my tank?lf I have a dirty screen I want to replace it. Ethanol in the fuel slowly builds up on the brass screen (on the petcock) this is what also clogs the small passages in the carbs, it turns into a brown hard mineral like substance. It not necessarily actual dirt that is building up in your fuel tank...and it's always wise to use and in line (paper element) fuel along with these screens. 2 Share this post Link to post Share on other sites
Cadmandu 67 #16 Posted April 17, 2019 Does using seafoam in the tank help Share this post Link to post Share on other sites
JAinVA 4,638 #17 Posted April 17, 2019 Like Jeff says ethanol free fuel is what you need and the only stuff I use in the air cooled engines.I would use it in the bigger tractors but it cost to much for what they burn.I recommend Sea Foam as a cleaning additive.I add some to the fuel and I'm sure some others use it as well. 1 Share this post Link to post Share on other sites
Cadmandu 67 #18 Posted April 17, 2019 Where can i buy fuel like that Share this post Link to post Share on other sites
ebinmaine 73,034 #19 Posted April 18, 2019 2 minutes ago, Cadmandu said: Where can i buy fuel like that pure-gas.org 2 Share this post Link to post Share on other sites
richmondred01 2,307 #20 Posted April 18, 2019 As for fuel pumps. The older aluminum ones I rebuild because I still have several NOS Kohler kits for them. If it has the plastic newer style, I don’t even waste my time, they are inexpensive so I just put a new one on and trash the old one. I buy them in bulk like the fuel shut off valves, transmission rubber boots, fuel filter, air cleaners, carb rebuild kits, points, plugs condensers, and gaskets. These items, like predator engines, (ha) are expendable items and get tossed. 2 Share this post Link to post Share on other sites
Cadmandu 67 #21 Posted April 18, 2019 Thanks I found one 12 miles away. 10 gal should get me through the year Share this post Link to post Share on other sites
Cadmandu 67 #22 Posted April 18, 2019 You must have a repair shop. I think I have an aluminum one do I need a kit if so can you tell me where to buy. I have a 1989 312-8 pre Toro Share this post Link to post Share on other sites
richmondred01 2,307 #23 Posted April 18, 2019 I’m not sure where you buy the old fuel pump kits anymore. I bought a bunch at an auction when shop closed years ago. i haven’t had to buy any in years. Share this post Link to post Share on other sites
Cadmandu 67 #24 Posted April 18, 2019 As long as the diaphragm is not bad can you just soak and clean Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #25 Posted April 18, 2019 8 minutes ago, Cadmandu said: Thanks I found one 12 miles away. 10 gal should get me through the year 10 gallons for the year? Are you sure especially if you mow once a week till fall. 2 1 Share this post Link to post Share on other sites
