Mike s 0 #1 Posted April 16, 2019 (edited) I have a 417-8 wheel horse that has a model 05-48ms04 mower deck, that needs two ( 106063 ) spindle housings due to corrosion at the bolt holes. These seem to be unavailable new and used ones are hard to find. Does anyone know were to find new or used spindle housing or a substitute. Edited April 16, 2019 by Mike s Share this post Link to post Share on other sites
daveoman1966 3,881 #2 Posted April 16, 2019 Go here...best price I've found for JUST the housing....if you other parts are ok. https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO//106063/1/ Ebay MAY have the complete housing for less.... the 2" and 48" spindles are the same spindle. Jusat be sure to get one that DOES NOT use the Woodruff Key in the top pulley. You can buy the WHOLE assembly for $115 at the same place... https://www.psep1.biz/arinet.asp?aribrand=TO#/Toro_Consumer/05-48MS04%2c_48"_Side_Discharge_Mower%2c_300_and_400_Series%2c_1985/REAR_DISCHARGE_MOWER-42_IN._(107_CM)_(VEHICLE_IDENTIFICATION_NUMBER_05-42MR03)/05-48MS04-245-1985/810388R1-88R10011-0006 2 Share this post Link to post Share on other sites
Mike s 0 #3 Posted April 18, 2019 I tried to order this spindle housing 106063 from Pat's small engine repair and is no longer available. I will have to wait for this item to come up on Ebay. Thanks daveoman 1966 Share this post Link to post Share on other sites
daveoman1966 3,881 #4 Posted April 18, 2019 (edited) 3 hours ago, Mike s said: I tried to order this spindle housing 106063 from Pat's small engine repair and is no longer available. I will have to wait for this item to come up on Ebay. Thanks daveoman 1966 tHOUGHT i found it...wrong. Edited April 18, 2019 by daveoman1966 Share this post Link to post Share on other sites
