Countdown To Christmas!
OlScrappy
D160 engine to hydro pump
OlScrappy
I am looking for the engine to hydro pump adaptor for a D160 that mounts on the hydro pump. It is made of cast an splined .
OlScrappy
Thanks for the info i appreciate it !
dells68
Try A-Z.  I would bet he has some good used ones.  He bought several D’s almost a couple of years ago at an auction in Charlottesville, VA.  Lincoln is a good guy!
Sarge
Have you had a problem with that splined shaft stripping from wear? Might want to search this forum - this has been addressed quite a few times and it is a common weak spot in the big D's design.
Might want to read through this thread -
https://www.wheelhorseforum.com/topic/72096-d-180-pump-coupling-alignment/?tab=comments#comment-685635
Sarge
