ed4stoy99@yahoo.com 2 #1 Posted April 12, 2019 I'm new to this so sorry if it's been asked before but why is gas coming out of this hole? I put all new gaskets on it. Any help would be much appreciated. Thanks 1 Share this post Link to post Share on other sites
roadapples 6,986 #2 Posted April 13, 2019 Aaaaah, what hole??? 1 1 Share this post Link to post Share on other sites
rjg854 12,832 #3 Posted April 13, 2019 You know The one he posted about 2 1 Share this post Link to post Share on other sites
953 nut 63,971 #4 Posted April 13, 2019 15 hours ago, ed4stoy99@yahoo.com said: why is gas coming out of this hole? We could use a little help here! or at least a good through description. Share this post Link to post Share on other sites
roadapples 6,986 #5 Posted April 13, 2019 Didn't mean to be a hole myself, a-hole that is, but you're not giving us much information..... Share this post Link to post Share on other sites
ed4stoy99@yahoo.com 2 #6 Posted April 13, 2019 Lol . Sorry gas is coming out of the valve cover.. I'm a real green horn with small engines. Share this post Link to post Share on other sites
ed4stoy99@yahoo.com 2 #7 Posted April 13, 2019 I thought I posted a video too ..but guess that didn't load. My bad. 1 Share this post Link to post Share on other sites
305 380 #8 Posted April 13, 2019 (edited) green horn or old pro, you give us nothing to go on........what is the make and model of motor ? i'm not sure if any Wheelhorses had an engine with an actual valve cover ? Edited April 13, 2019 by 305 Share this post Link to post Share on other sites
ed4stoy99@yahoo.com 2 #9 Posted April 13, 2019 Also when gas is coming out of the valve cover the motor still runs like a top. Share this post Link to post Share on other sites
squonk 45,377 #10 Posted April 13, 2019 If by valve cover you mean breather cover your fuel pump is leaking gas into the oil. Do not run engine anymore until fixed! 1 Share this post Link to post Share on other sites
ed4stoy99@yahoo.com 2 #11 Posted April 13, 2019 And there is the problem. Just checked the oil and it's like a cup of coffee..Black and thin. Damn ...Thanks for the advice. 1 1 Share this post Link to post Share on other sites
oldredrider 2,553 #12 Posted April 13, 2019 Drain the crankcase. Pull the carb and clean and inspect it thoroughly. Chances are your carb float is stuck causing gas to leak into the crankcase. 1 1 Share this post Link to post Share on other sites
pfrederi 19,794 #13 Posted April 13, 2019 Or you fuel pump diaphragm has failed and it is letting gas into the crank case.... 3 Share this post Link to post Share on other sites
squonk 45,377 #14 Posted April 13, 2019 His engine runs fine. That's why I said fuel pump. Check both to be positive 2 Share this post Link to post Share on other sites
