timmy b 10 #1 Posted April 11, 2019 I have a 1996 314-8 Automatic with a Kohler K14-601559 engine. The float switch at the base of the engine may have failed. The Toro part# 92-7278 has been discontinued and is unavailable. Can someone direct me to a replacement part or can the switch be bypassed and not used? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #2 Posted April 11, 2019 Has the switch failed or does it require service? Be sure to read this before you attempt to remove it. Simply unplugging the switch will allow some models to start. Will have to check the wiring diagrams to see if that applies to your model. Garry Share this post Link to post Share on other sites
953 nut 70,312 #3 Posted April 11, 2019 If you test it and find out you need one I have a couple NOS Kohler Oil Switches listed on . NOS KOHLER 25 704 03 OIL SENTRY SWITCH, NEW OLD STOCK, GENTECH INT. LEVEL SWITCH Make an offer with a Red Square 33% discount. Share this post Link to post Share on other sites
