Gary520H 2 #1 Posted April 10, 2019 Hello all! Yesterday I replaced my drive belt and idler pulley. While installing belt I had to remove white plastic fan. After installing belt, idler pulley and fan I'm not sure I have installed the fan correctly. Does anybody have a picture or description on which way is the right way? I wanted to make sure I have installed correctly before installing seat pan. Thanks. Gary Share this post Link to post Share on other sites
JAinVA 4,638 #2 Posted April 10, 2019 Not the best photo but it should help.There is a blade missing from the fan. Share this post Link to post Share on other sites
Gary520H 2 #3 Posted April 11, 2019 Thanks for the quick response and photo. I have it on correctly. Thanks again. Gary. Share this post Link to post Share on other sites
Sarge 3,471 #4 Posted April 12, 2019 The pulley spins counterclockwise on the WH transmissions, hydro or gear drive - the fans on the hydro are intended to blow air across the fins for cooling. Sarge Share this post Link to post Share on other sites
