dwcphoto 7 #1 Posted April 7, 2019 Hi folks, I tried a search with no luck and I know it’s already here somewhere. Can someone direct me to onan 18 surging issue at mid and lower rpms? Thanks! Dc Share this post Link to post Share on other sites
pacer 3,179 #2 Posted April 8, 2019 11 minutes ago, dwcphoto said: already here somewhere. Gosh yeah! These dern Onans are seemingly notorious for surging/hunting. There are probably dozens of posts here and also on utube. Typing "onan surging pulsing" in search should bring up MANY topics. Generally (most likely) its in the carb, they are really finicky - clean it well, maybe adding a kit while its apart, The mixture and idle adjustments are quite 'touchy' and can sometime be a pill to get set. Share this post Link to post Share on other sites
dwcphoto 7 #3 Posted April 8, 2019 Appreciate that. I'll try the search again. This is my first problem with surge or hunting and I bought the thing used back in 96. Does not get babied, shame on me. Sits under a roof in an open shed all year, pull a trailer for stone and firewood and mows mostly rough ground. Put a set of plugs in it once, a vaccum line and fuel lines, plus a 520 rear and it just keeps ticking. Oh, and a cleaning of the breather some years ago. I'll take a look in the carb and do another search. Thank you again. The folks here are always very helpful. best, dwc Share this post Link to post Share on other sites
ET160 30 #4 Posted April 11, 2019 I would say carb, too. Clean and adjust. Share this post Link to post Share on other sites
dwcphoto 7 #5 Posted April 11, 2019 Beauty, I have a can of carb cleaner. I've taken that apart to do the breather one time, so I just need a couple hours to get at it. Thank you! David Share this post Link to post Share on other sites
