Stormin 9,986 #1 Posted April 5, 2019 Decided to give the fleet a service yesterday. Engine oil on all except the C-125. That was done after the rebuild. So C-81, The Black Horse and Sears/Roper all got new blood. The trans were drained by jacking up the front and a 3" block under the RH rear wheel. I only did the C-81 and C-125. The oil in the other two was done last year and still clean. I did find both RH rear tyres on the C-81 and C-125 had no air in. C-81 possibly not sealing and the C-125 has a split valve. They'll be sorted next week. Today was grease day. Every grease nipple I could find got done. Much to my surprise the Sears/Roper had no grease nipples in the axle spindles. Holes yes. Nipples no. Also no way to grease the axle pivot. OK! I'll do something about that. Jack up the front and lower on to axle stands. Keep the H&S bods happy. Removed the track rods from the spindles and spindles complete with wheels. Why make work. Then the axle itself after removing the front hitch. With that on you couldn't remove the pivot bolt. Drilled out the holes for the nipples and re-threaded to take the larger nipples I had. The nipples protruded into the spindle tube, so thin washers were used to pack them out. Next the pivot bolt. This was over long so lost a1/4" then into the lathe to have a grease hole drilled up the centre. Then a hole drilled through the bolt shank halfway along. Finally the end threaded to take a grease nipple. All back together and greased. Quote Edit Hide all signatures I've been to Midsomer and survived. 1975 Raider 10. Future project. 1978 Sears/Roper. GT16. 1978 C-121 custom. The Black Horse. 1979 C-81 Commando 800. 1982 C-125.Old Faithful. Home built land roller. Home built snow/dozer blade. Home built mid mounted grader blade. Auto Culto single furrow plough. 1963 Wheel Horse Sickle 7 8 Share this post Link to post Share on other sites
