Howie 900 #1 Posted April 4, 2019 Saw something today I had heard about but never seen before. Fellow brought me a K241 this week to grind the valves on and possibly put in a new set of rings. Cleaned top of piston off and it is marked .003. Will see where this goes. Share this post Link to post Share on other sites
ebinmaine 77,079 #2 Posted April 4, 2019 I don't have enough knowledge of the Small Engine World to say that I've seen one of those... In big engines however, quite a few times. It was an old trick we used to use many moons ago when we did not want to spend the money or take the time to have an engine bored out. Share this post Link to post Share on other sites
WHX?? 54,528 #3 Posted April 4, 2019 Very common Howie to have factory pistons marked that . Was some kinda factory thing been told. Measure things as should and bounce your findings off the specs to see if you can squeak by with a just a re-ring or gotta go 10/20/30 over. Check existing ring end gaps and piston to bore measures. Most importantly is the condition of the bore, out of roundness, taper and all that lovely stuff. Also the condition of the piston is of prime considerat ion 3 Share this post Link to post Share on other sites
Howie 900 #4 Posted April 4, 2019 I have never seen them listed in the parts manuals, think the factory did this to use a block bored a little large. At least that is what I have read before. 2 Share this post Link to post Share on other sites
Achto 30,847 #5 Posted April 4, 2019 2 minutes ago, Howie said: I have never seen them listed in the parts manuals, think the factory did this to use a block bored a little large. At least that is what I have read before. This is exactly the info that my research has came up with also. 2 Share this post Link to post Share on other sites
ebinmaine 77,079 #6 Posted April 4, 2019 5 minutes ago, Howie said: I have never seen them listed in the parts manuals, think the factory did this to use a block bored a little large. At least that is what I have read before. In the v8 car engines if they were worn fairly evenly 6 or 8 thousandths over they would use two or three thousand oversize Pistons, or maybe knurl the skirts. First I've seen of a small engine doing this but it definitely makes sense. Share this post Link to post Share on other sites
WHX?? 54,528 #7 Posted April 4, 2019 (edited) In a nutshell Howie if you see one with a 003 marking consider it factory and measure accordingly.. There is no substitute for accurate measuring. Edited April 4, 2019 by WHX22 1 1 Share this post Link to post Share on other sites
Howie 900 #8 Posted April 4, 2019 I have rebuilt quite a few of these engines but the first one I have ever run into like this. Had heard of it just never saw one. I have bore gave and all I need to check the block. Cylinder looks good will have to see what the piston looks like. 1 Share this post Link to post Share on other sites
WHX?? 54,528 #9 Posted April 4, 2019 Same here Howie ... I'm sure other guys will be along to chime in about the 003 business. That's why I am just suggesting measure, those figures tell the truth. Share this post Link to post Share on other sites
Achto 30,847 #10 Posted April 4, 2019 Kohler rings from OPE engines. https://www.kohler-engine-parts.opeengines.com/index.php?main_page=product_info&products_id=6108 2 1 Share this post Link to post Share on other sites
953 nut 63,974 #11 Posted April 4, 2019 Long and short of it is that in the manufacturing process not all blocks came down the line with a perfect cylinder. Some were re cut at .003 over to save the block, some even left the factory at .010 over. 3 1 Share this post Link to post Share on other sites
Pullstart 68,776 #12 Posted April 4, 2019 1 hour ago, 953 nut said: Long and short of it is that in the manufacturing process not all blocks came down the line with a perfect cylinder. Some were re cut at .003 over to save the block, some even left the factory at .010 over. There’s no replacement for displacement! 1 Share this post Link to post Share on other sites
WHX?? 54,528 #13 Posted April 4, 2019 (edited) 11 hours ago, Achto said: Kohler rings from OPE engines. They ain't exactly given them rings away tho are they? I suppose OEM Kohler! Wonder if the rings for a std bore were commonly used with the 003 piston? Keep us informed with what shakes Howie, the number of 241's I have to eventually go through I am more than likely going to run into this. Next question was a 003 used on the other K series or M blocks? looking at Dan's link to those rings it says they are for a 341 so I'm thinkin so? From the link Piston Rings Standard & .003 Bore, Fits new style Mahle piston design used in K341 & M16 engines. 45 108 10-S Edited April 4, 2019 by WHX22 Share this post Link to post Share on other sites
Achto 30,847 #14 Posted April 4, 2019 29 minutes ago, WHX22 said: Wonder if the rings for a std bore were commonly used with the 003 piston? Dealing with only .003 I would think it would have been common. .003 would be past the wear limits of the piston but still within reach for the rings 2 Share this post Link to post Share on other sites
oldredrider 2,553 #15 Posted April 4, 2019 It is recommended by Kohler to use standard rings on a .003 over piston. It's not really uncommon to run across the .003 blocks...but then, I've done "quite a few" Kohlers. 3 Share this post Link to post Share on other sites
953 nut 63,974 #16 Posted April 4, 2019 (edited) 8 hours ago, WHX22 said: They ain't exactly given them rings away tho are they? I suppose OEM Kohler! Best place is on . I have sold a lot of NOS Kohler ring sets for $ 25.00 with free shipping. I don't have any K-241/M-10 rings or I would have PMed by now. Edited April 4, 2019 by 953 nut fat finger 1 Share this post Link to post Share on other sites
WHX?? 54,528 #17 Posted April 4, 2019 Agreed Richard, I see them resonable ther in old tattered nos boxes but then I see them for $$$$. Of all the aftermarket stuff to keep these motors running I personally would like to use Kohler rings. Unfortunately this being a hobby and I'm not looking for pulling champion prize money or flying at 33k ft my wallet tells me to settle for Chinese. 2 1 Share this post Link to post Share on other sites
Spareparts 92 #18 Posted April 10, 2019 How much are you paying for 341 K-series rings, ordered Kohler rings and just about died $181.00 did I get taken???? 2 Share this post Link to post Share on other sites
Achto 30,847 #19 Posted April 11, 2019 8 hours ago, Spareparts said: did I get taken???? Hate to say, but I fear you may have. http://www.psep.biz/store/kohler_piston_rings.htm Share this post Link to post Share on other sites
953 nut 63,974 #20 Posted April 11, 2019 Lots of genuine New Old Stock rings on for $ 35 to $ 40. Share this post Link to post Share on other sites
Spareparts 92 #21 Posted April 14, 2019 I thought so, but the bad part is they are sitting on my bench and I don't think I will build that engine now. 1 Share this post Link to post Share on other sites
