raywilson12 8 #1 Posted April 2, 2019 Ok now that i have a way to make my belt guard work ( Thanks again @Achto !) I was woundering what the engine base plate looks like? i have an H60 that came with it but its bolted into holes someone cut with a cutoff wheel. is there a mounting plate? or is this the wrong motor? Share this post Link to post Share on other sites
Achto 31,542 #2 Posted April 2, 2019 (edited) 8 hours ago, raywilson12 said: is there a mounting plate? or is this the wrong motor? It does appear that there should be a mounting plate for the Techy H60. Here is a manual to down load for your tractor. These are very handy when doing a resto, it will have exploded views as well as part numbers. Edited April 2, 2019 by Achto 2 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted April 2, 2019 Ray I have a mounting plate if you need one . Pm me and let me know. Thanx. Randy 3 Share this post Link to post Share on other sites
raywilson12 8 #4 Posted April 2, 2019 Thank you guys! This is a huge help! 1 Share this post Link to post Share on other sites
raywilson12 8 #5 Posted April 2, 2019 What about the gov setup? anyone have pictures? Share this post Link to post Share on other sites
The Tuul Crib 7,354 #6 Posted April 2, 2019 2 minutes ago, raywilson12 said: What about the gov setup? anyone have pictures? Might try the manual section and type in what you have . Course someone might have a pic as well Share this post Link to post Share on other sites
