upstate yank 219 #1 Posted March 31, 2019 i was wondering if anyone might know if a 12 horse kohler motor would both down the the frame of a command 8 other than changing the bottom oil pan plus would it sit to high and the hood wouldn't close ;please bear with me as something like this is all new to me as i would really like to get the commando 8 up and running ;selling for parts would be an option but really for the shape it is in for the year i would rather not 'thanks everyone and i look forward to your advise; Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted March 31, 2019 It should bolt down fine. I bolted down a 14 hp on a 1067 frame and the right side bolts up from the bottom. The only issue I had was the way the oil pan drained. I just reversed it. 1 1 Share this post Link to post Share on other sites
953 nut 63,971 #3 Posted April 1, 2019 Kohler engines used two types of oil pans. If it is the one that bolts directly to a frame then it will work. If it was bolted to a "Shaker Plate" the you have some work to do. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted April 1, 2019 1 hour ago, 953 nut said: Kohler engines used two types of oil pans. If it is the one that bolts directly to a frame then it will work. If it was bolted to a "Shaker Plate" the you have some work to do. 1 Share this post Link to post Share on other sites
upstate yank 219 #5 Posted April 1, 2019 4 hours ago, The Tool Crib said: It should bolt down fine. I bolted down a 14 hp on a 1067 frame and the right side bolts up from the bottom. The only issue I had was the way the oil pan drained. I just reversed it. thanks so much for the input i know i might have to exchange the base but that is no problem as i would really would like to get the old 72 up and running ;but i am concerned that a 12 horse might be a little higher and effect the closing of the hood ;again this is all new to me ;again thank you so much Share this post Link to post Share on other sites
upstate yank 219 #6 Posted April 1, 2019 50 minutes ago, The Tool Crib said: thanks so much for the input as far as the shaker plate that i am not sure about as again this is all new to me but i know looking at the 8 horse bolted to the frame on the commando 8; it does sit flush now on the 12 i really don't know 'but i am concerned that the 12 horse will sit a little higher and have issues closing the hood ;i for sure will let you know and again thanks so much as i really appreciate it Share this post Link to post Share on other sites
Racinbob 12,669 #7 Posted April 1, 2019 I'm curious about hood clearance too. As much to the front as overhead. Of course you wouldn't use the plate the 8hp is sitting on but it still looks tight to me. The Commando hood is more compact than the B's that followed it up. Share this post Link to post Share on other sites
rmaynard 16,840 #8 Posted April 1, 2019 Just so everyone is on the right page, there is no 1972 Commando 8. Before we start talking about what engines will fit on what tractor, we should really know what you have. Can you give us the ID number from the tag? Share this post Link to post Share on other sites
Racinbob 12,669 #9 Posted April 1, 2019 Very true Bob. I just read it as Commando 800. Share this post Link to post Share on other sites
