T-Mo-(Moderator) 4,666 #1 Posted March 27, 2019 If anyone remembers, my "good" 953 has an issue with the lever not operating the pump. See video below. I posted this last year and I believe I was told the spring broke inside the pump. So I need to remove it. My question is, before I break something, how does the pulley come off the pump. A puller? Set screw? etc. 1 Share this post Link to post Share on other sites
Achto 30,054 #2 Posted March 27, 2019 (edited) There should be a set screw holding the pulley on. Spray it down good with penetrating fluid and use a puller to remove the pulley. Here is some very important info. Do not hit the shaft with a hammer unless you have the whole pump taken apart. You will chance damaging one of the gears inside the pump. Don't ask me how I know this. Edited March 27, 2019 by Achto 4 1 1 Share this post Link to post Share on other sites
953 nut 62,639 #3 Posted March 27, 2019 I have always found that once the set screw is removed the pulley comes right off because the pump seal has leaked enough to prelubricate the shaft. 4 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,666 #4 Posted March 27, 2019 Thanks, guys. Share this post Link to post Share on other sites
Shynon 7,492 #5 Posted March 27, 2019 2 hours ago, 953 nut said: I have always found that once the set screw is removed the pulley comes right off because the pump seal has leaked enough to prelubricate the shaft. 2 1 Share this post Link to post Share on other sites
WHX?? 53,081 #6 Posted March 27, 2019 Does the cylinder move when you move the lever T? If so the and the lever doesn't return to neutral yes the spring broke which is the most common. If the cylinder doesn't move then you may have a bad gear like Dan's. The good news and you may already know this is that Lowell has complete kits including the gears. 1 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,666 #7 Posted March 27, 2019 7 minutes ago, WHX22 said: Does the cylinder move when you move the lever T? If so the and the lever doesn't return to neutral yes the spring broke which is the most common. If the cylinder doesn't move then you may have a bad gear like Dan's. The good news and you may already know this is that Lowell has complete kits including the gears. The latter - the lever moves but there is no movement of the cylinder nor is there any resistance of the lever itself. Luckily I have another 953 that I could steal the pump from until I get this one fix. 1 1 Share this post Link to post Share on other sites
Achto 30,054 #8 Posted March 27, 2019 (edited) 43 minutes ago, T-Mo said: Luckily I have another 953 that I could steal the pump from until I get this one fix. As a note, when you get around to rebuilding that pump. All of the parts are removed from the inside of the pump. There is a snap ring on the out side of the valve drum, remove this and push the drum in. The reason for this note is that there is a slight taper to the valve drum and it will not push out from the inside very easily or without minor damage. Edited March 27, 2019 by Achto 3 1 Share this post Link to post Share on other sites
