Digger 66
Plow question
Digger 66
I think I want to purchase a blade for my '72 Raider 10 .
Sooo ... what blades and frames will bolt up to this tractor ?
gwest_ca
Any of these should fit
1970-73 model [6-4113 + 6-9622]
1973-74 model [6-4113 + 6-9623]
1974 model [6-4114 + 6-9624]
1974 model 6-2131
1975 model 6-2132
1976 model 6-2133
1976 model 66-42BC01
1977 model 76-42BC01
1978 model 86-42BC01
1979 model 96-42BC01
1980 model 06-42BC01
1981-1984 model 06-42BC02 (Up to here they are 42" wide)
1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following
1990 model 06-48BC02
1991-1993 model 06-48BC03
1993-2001 model 79350
2002 2004-2009 2012 model 79364
Garry
squonk
Pretty sure the Raider is a long frame tractor. So any C,300-500 series frame will fit. Plow angle levers may pose an issue with running boards. If the Raider is a short frame, a long frame plow will fit if it has the extra set of holes in the rear of the frame.
I have a long frame C series plow on my short frame 857.
roadapples
Long frame..
ebinmaine
:text-yeahthat:
My C160 came with a plow that had a lever that didn't fit quite right.
I now have a 82-89' 48" plow on it and the lever is still close but works better.
Digger 66
You guys think this sucker will work ?
He's asking $175.00
ebinmaine
You should be fine with that one. Whereas the last couple feet of rail is parallel to one another that makes it a long frame plow. They will also work on Mid frames and short frames.
That's also a  good price in most regions of the country.
