Digger 66 3,524 #1 Posted March 22, 2019 I think I want to purchase a blade for my '72 Raider 10 . Sooo ... what blades and frames will bolt up to this tractor ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted March 22, 2019 Any of these should fit 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 1991-1993 model 06-48BC03 1993-2001 model 79350 2002 2004-2009 2012 model 79364 Garry 1 Share this post Link to post Share on other sites
squonk 45,536 #3 Posted March 22, 2019 Pretty sure the Raider is a long frame tractor. So any C,300-500 series frame will fit. Plow angle levers may pose an issue with running boards. If the Raider is a short frame, a long frame plow will fit if it has the extra set of holes in the rear of the frame. I have a long frame C series plow on my short frame 857. 2 Share this post Link to post Share on other sites
roadapples 6,987 #4 Posted March 23, 2019 2 hours ago, squonk said: Pretty sure the Raider is a long frame tractor. So any C,300-500 series frame will fit. Plow angle levers may pose an issue with running boards. If the Raider is a short frame, a long frame plow will fit if it has the extra set of holes in the rear of the frame. I have a long frame C series plow on my short frame 857. Long frame.. Share this post Link to post Share on other sites
ebinmaine 77,358 #5 Posted March 23, 2019 13 hours ago, squonk said: Plow angle levers may pose an issue with running boards My C160 came with a plow that had a lever that didn't fit quite right. I now have a 82-89' 48" plow on it and the lever is still close but works better. 1 Share this post Link to post Share on other sites
Digger 66 3,524 #6 Posted March 25, 2019 You guys think this sucker will work ? He's asking $175.00 Share this post Link to post Share on other sites
ebinmaine 77,358 #7 Posted March 25, 2019 You should be fine with that one. Whereas the last couple feet of rail is parallel to one another that makes it a long frame plow. They will also work on Mid frames and short frames. That's also a good price in most regions of the country. 1 Share this post Link to post Share on other sites
