RT WH416H 10 #1 Posted March 18, 2019 I got this a few months ago and has worked fine. All of the sudden, it will not start. The lights on the dash appear to work and made sure seat switch was working along with the others. Is it normal for the light for the oil blinks? There is oil, there is a new coil, battery is fine. Any suggestions??? Thanks in advance...Rob Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #3 Posted March 18, 2019 The oil lights all blink if they are on. They are never a steady light. It will blink until the oil pressure comes up. By not start do you mean it turns over on the starter but will not run on it's own? See if you have battery power at the coil + while cranking and again with the key in the run position even if it is not running. Garry 1 1 Share this post Link to post Share on other sites
pfrederi 19,810 #4 Posted March 18, 2019 416 ws around for awhile K series Kohler, Magnums and Onans. Different wiring what are we dealing with here 2 Share this post Link to post Share on other sites
