Evil Archer 300 76 #1 Posted March 9, 2019 Any tips on removing the drain plug. I just purchased a 416-8 and think it would be a good idea to drain the Transaxle. Share this post Link to post Share on other sites
ebinmaine 77,518 #2 Posted March 10, 2019 Are you talking about the drain plug that is at the very bottom of the transmission? Not the one that is on the side? If so, I've never seen one stuck because they sit in gear oil. Appropriate sized allen wrench and try to tighten it just a hair first, then loosen it. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,347 #3 Posted March 10, 2019 Here’s a tool I have found to be very handy for this to particular thing . It is a plumbing tool I picked up at Home Depot a few years back. Fits perfectly on the drain plug 2 Share this post Link to post Share on other sites
rjg854 12,860 #4 Posted March 10, 2019 It's a faucet seat wrench, that should supply a lot of leverage. Share this post Link to post Share on other sites
pfrederi 19,941 #5 Posted March 10, 2019 1/4" allen wrench clean out teh crud that is in the hole first. 3 1 Share this post Link to post Share on other sites
The Tuul Crib 7,347 #6 Posted March 10, 2019 31 minutes ago, rjg854 said: It's a faucet seat wrench, that should supply a lot of leverage. It worked great for me! Share this post Link to post Share on other sites
peter lena 9,779 #7 Posted March 10, 2019 while you are at it , its probably a good time to replace the shiftier boot, they usually crack and let in moisture, about 9 $ on the net. use silicone grease on shiftier rod for smooth easy install , Pete 3 Share this post Link to post Share on other sites
