Herder 2,356 #1 Posted March 9, 2019 Carb cleanings and adjustments just weren't cutting it. The old Charger 12 was running like crap. New carb and gaskets sent straight to the door. 1 year warranty The shaft for the choke needed to be changed. Notice the tape on the left side of the carb!! Its there for a reason. That little BB is spring loaded and when you remove the shaft it fly's out, hits you in the eye and causes temporary blindness. Needless to say that BB is imposable to find once you've lost track of it. I use thread lock when reinstalling the screws. Runs like a top. choose files...---------Click to choose files.url 2 Share this post Link to post Share on other sites
peter lena 9,952 #2 Posted March 10, 2019 herder , i can relate to I SAVE TRACTORS , picked up a carb to eliminate a problem , and it was more than worth it. never had to touch it ! . started , idled , and runs with out any issues. just getting rid of one of your problems , makes sense, just my opinion , Pete Share this post Link to post Share on other sites
Herder 2,356 #3 Posted March 10, 2019 (edited) 6 hours ago, peter lena said: herder , i can relate to I SAVE TRACTORS , picked up a carb to eliminate a problem , and it was more than worth it. never had to touch it ! . started , idled , and runs with out any issues. just getting rid of one of your problems , makes sense, just my opinion , Pete I have ordered a few carbs, gasket sets and some other item from IST and have never had an issue. I like his carburetors, they install and work perfectly with little to no adjustments. Edited March 10, 2019 by Herder 2 Share this post Link to post Share on other sites
