Ken1978kuduk
D180 Reverse issues
Ken1978kuduk
 I have a 1973 wheel horse D1 80 I’m having issues with the reverse not wanting to move my forward works fine could someone please give me a detailed description of where I should start to correct this issue thanks
pfrederi
Welcome to Red Square!!!
Download this manual. it has diagnostics.
First would be to check the linkage.  D linkage is complex and can slip out of adjustment
 manual will next send you to the reverse check valve on the pump.  The plug can be very difficult to remove.  I might skip ahead to the reverse acceleration valve on the hydro motor it is easier to deal with.
  i hope your issue is in the control linkage.  the other two possibilities are significant work.  Hope yo have a warm place to work...kind of cold here in PA right now.
