Evil Archer 300 76 #1 Posted March 2, 2019 I just bought a 416-8. Added it to my herd. I have a problem with the Clutch pedal pulsing up and down. With the Clutch engaged in neutral and while in gear. Any thoughts ? Share this post Link to post Share on other sites
Ed Kennell 45,023 #2 Posted March 2, 2019 It could be a bad idler pully bearing, or a bad spot on the belt, or a weak spring. Share this post Link to post Share on other sites
Evil Archer 300 76 #3 Posted March 2, 2019 It is constant ,So I don't think it's the belt. I'll check the Idler and spring tomorrow Thanks Share this post Link to post Share on other sites
wallfish 19,379 #4 Posted March 2, 2019 1 hour ago, Ed Kennell said: It could be a bad idler pully bearing, or a bad spot on the belt, or a weak spring. If the belt has a damaged spot or a chunk missing, it will cause the clutch pedal to pulse each time it comes around to the idler pulley, so might as well take a look if the idler pulley is good. Share this post Link to post Share on other sites
Evil Archer 300 76 #5 Posted March 3, 2019 I took the Belt off today and found a spot where it was just a little narrower . It would be just enough to make a pulse. The idler looked perfect and the spring appears to be good. I need to know the lenght of the belt. I have a 310-8 that I removed the drive belt and it was too short. Share this post Link to post Share on other sites
Ed Kennell 45,023 #6 Posted March 3, 2019 I would take the belt to TSC or NAPA and let them match the size. Make sure you get a belt that is designed to run an idler on the back side. TSC green is my belt of choice. Share this post Link to post Share on other sites
WHX?? 55,192 #7 Posted March 3, 2019 Find the WH part no and thers a chart that crosses the P/N to length. I don't have the chart on my phone but the fellas will help you find it if need be. Share this post Link to post Share on other sites
