Larry Chamberlain 16 #1 Posted February 22, 2019 Looking into gettingba snow blower for my 73 work horse what is a good blower for it was wondering if a stage 2 would work on it or not thanks Share this post Link to post Share on other sites
Ed Kennell 35,809 #2 Posted February 22, 2019 What HP engine ? Gear drive or hydro? 1 Share this post Link to post Share on other sites
Larry Chamberlain 16 #3 Posted February 22, 2019 12hp gear drive Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #4 Posted February 22, 2019 17 hours ago, Larry Chamberlain said: Looking into gettingba snow blower for my 73 work horse what is a good blower for it was wondering if a stage 2 would work on it or not thanks It's not that it wouldn't work as much as it would be working you and that tractor, the Toro 2stage was designed for the twin cylinder hydro/hydralic tractors (416-520) IMHO a 14 hp single would be the absolute minimum...as the PO of my 2stage had it installed on a 314-8...now with that being said I had a tall chute single for years and the biggest difference between the two is the 2stage can chew through DOT plow banks without clogging, if I were in your position a newer tall chute single stage easier to install, lift , maintain and less strain on the tractor again just my opinions and experiences, Jeff. 2 Share this post Link to post Share on other sites
pfrederi 17,147 #5 Posted February 22, 2019 (edited) A lot depends on what and how much you have to clear. I ran a single stage on a 12hp hydro for a few years. In recent years went to a 16 hp hydro Did a 28 inch snowfall two years ago. i live on a hill that is windy I do not need or want to blow snow 30 ft in the air. 8-10 feet laterally is more than enough to get it out of the driveway. No comments about the hat. This was the Charger 12 several years ago Edited February 22, 2019 by pfrederi 3 Share this post Link to post Share on other sites
Ed Kennell 35,809 #6 Posted February 22, 2019 I agree with Jeff and Paul. I ran a single stage on a C-120 Hydro for years and it did Ok, only running out of power in the heaviest deepest snow. Your 12 HP gear drive would have enough power to operate a single, but would be laboring to spin a two stage. I have my single stage on a 520 Hydro now. I really believe the single stage blowers work best when the ground speed is adjusted to keep the blower housing full, and the hydros with infinite speed adjustment makes this possible. The convenience of the hydraulic lift and ability to change direction instantly is invaluable when blowing and plowing snow. 2 1 Share this post Link to post Share on other sites
Sarge 3,462 #7 Posted February 23, 2019 18 hours ago, pfrederi said: A lot depends on what and how much you have to clear. I ran a single stage on a 12hp hydro for a few years. In recent years went to a 16 hp hydro Did a 28 inch snowfall two years ago. i live on a hill that is windy I do not need or want to blow snow 30 ft in the air. 8-10 feet laterally is more than enough to get it out of the driveway. No comments about the hat. This was the Charger 12 several years ago 2 Absolutely nothing wrong with that hat, Paul - I have one similar for hardhats and use it quite often. If you saw the damage from frostbite on my left ear that never goes away - you'd tighten the straps on that hat until your eyeballs bulged out. That Charger is one of the best tractor series ever made for snow or dirt work - limited slip rear axle, plenty of power and pure WH simplified build, can't beat it. I love a gear drive for a tiller, otherwise - hydro all the way. Sarge 1 1 Share this post Link to post Share on other sites
Larry Chamberlain 16 #8 Posted February 26, 2019 Ok guys thanks single stage it is I've seen enough of them for sale pretty cheap cheapest I've seen has been around 200 2 Share this post Link to post Share on other sites
Reel Mower Freak 125 #9 Posted February 26, 2019 12 hours ago, Larry Chamberlain said: Ok guys thanks single stage it is I've seen enough of them for sale pretty cheap cheapest I've seen has been around 200 I’ve picked up a single stage for $50. They’re out there. Sadly not a lot of people see the value in these old girls. Rather buy a crap blower from a big box store. If you were closer I’d give you one. Share this post Link to post Share on other sites
