Kasweld 7 #1 Posted February 21, 2019 Hi all could you please inform me of the correct dating for my wheelhorse please getting confused as have been told numerous dates and just want to know the correct one many thanks karl Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted February 21, 2019 Your serial number 10072 was added to the list in the past. Click on the picture Garry Share this post Link to post Share on other sites
The Tuul Crib 7,340 #3 Posted February 21, 2019 That looks like a later 80's model,and looks to be in great shape too !Very nice! I have a 312-8 and I love it!! to Share this post Link to post Share on other sites
Kasweld 7 #4 Posted February 21, 2019 Great thanks once again, thanks for positive comments, few repairs here and there, onto fitting a tiller to it next Share this post Link to post Share on other sites
953 nut 64,129 #5 Posted February 21, 2019 2 hours ago, Kasweld said: correct dating for my wheelhorse 2 9 Share this post Link to post Share on other sites
Reel Mower Freak 125 #6 Posted February 21, 2019 Thought he was having troubles hooking up. Title is catchy. 1 7 Share this post Link to post Share on other sites
Ed Kennell 44,904 #7 Posted February 21, 2019 1 hour ago, 953 nut said: Thactors ??????????????????? 1 2 Share this post Link to post Share on other sites
JoeM 9,622 #8 Posted February 21, 2019 Imagine what the pups would look like! 2 Share this post Link to post Share on other sites
squonk 45,536 #9 Posted February 21, 2019 Well there is smoke coming out of 1 of them! 1 Share this post Link to post Share on other sites
Kasweld 7 #10 Posted February 21, 2019 So it’s a 1987? Share this post Link to post Share on other sites
AHenry014 128 #11 Posted February 21, 2019 what is the extra belt guard for on the right side? Share this post Link to post Share on other sites
Ed Kennell 44,904 #12 Posted February 21, 2019 5 minutes ago, AHenry014 said: what is the extra belt guard for on the right side? Extra? That's the only belt guard covering the transmission drive belt. Share this post Link to post Share on other sites
Ed Kennell 44,904 #13 Posted February 21, 2019 3 hours ago, Kasweld said: So it’s a 1987? The numbers on the deck indicate the deck was made in 1987 or 1988. If you want the tractor build date, we need the tractor numbers that can probably be found under the seat. Share this post Link to post Share on other sites
Kasweld 7 #14 Posted February 21, 2019 44 minutes ago, Ed Kennell said: The numbers on the deck indicate the deck was made in 1987 or 1988. If you want the tractor build date, we need the tractor numbers that can probably be found under the seat. Yeah, there not there any more ☹️ Share this post Link to post Share on other sites
AHenry014 128 #15 Posted February 21, 2019 49 minutes ago, Ed Kennell said: Extra? That's the only belt guard covering the transmission drive belt. Unless my eyes are deceiving me, i spot an extra belt guard NEXT to the factory drive belt guard. The floor board seems to be about a 1/3rd narrower and appears to have a notch cut into it where it angles upward, i would guess for a belt to travel through. Looks like it could guard a belt traveling rearward from one of the PTO grooves. I am definitely no WH guru, but i spot an oddity here! Share this post Link to post Share on other sites
wallfish 19,324 #16 Posted February 21, 2019 That belt guard does look awfully wide. Are you saying that it's a belt guard covering the original belt guard? Maybe home brew if it is. Never saw that before 1 Share this post Link to post Share on other sites
evanloock 248 #17 Posted February 21, 2019 The extra belt guard is for the powered bagger (the belt that powered the impeller) that used the canvas cover attached to the Wheel Horse dump cart. Made from the 70's through the 80's. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #18 Posted February 21, 2019 53 minutes ago, AHenry014 said: Unless my eyes are deceiving me, i spot an extra belt guard NEXT to the factory drive belt guard. The floor board seems to be about a 1/3rd narrower and appears to have a notch cut into it where it angles upward, i would guess for a belt to travel through. Looks like it could guard a belt traveling rearward from one of the PTO grooves. I am definitely no WH guru, but i spot an oddity here! That is an extra guard I see it now!! The regular belt guard rides flush with the center tower downward. Share this post Link to post Share on other sites
AHenry014 128 #19 Posted February 21, 2019 30 minutes ago, evanloock said: The extra belt guard is for the powered bagger (the belt that powered the impeller) that used the canvas cover attached to the Wheel Horse dump cart. Made from the 70's through the 80's. Cool!! Share this post Link to post Share on other sites
WHX?? 55,030 #20 Posted February 21, 2019 1 hour ago, Kasweld said: Yeah, there not there any more ☹️ That sucks....Get the numbers off the engine perhaps that will narrow down the year. 1 Share this post Link to post Share on other sites
Ed Kennell 44,904 #21 Posted February 21, 2019 1 hour ago, AHenry014 said: Unless my eyes are deceiving me, i spot an extra belt guard NEXT to the factory drive belt guard. The floor board seems to be about a 1/3rd narrower and appears to have a notch cut into it where it angles upward, i would guess for a belt to travel through. Looks like it could guard a belt traveling rearward from one of the PTO grooves. I am definitely no WH guru, but i spot an oddity here! Yeah, I see it now. May be Garry will post the file on this. I have never seen one of these and would like to see the pully system to get the drive belt to the rear mounted blower. 1 Share this post Link to post Share on other sites
JoeM 9,622 #22 Posted February 21, 2019 A friend of mine has a foot pad with a slot cut in from the factory for the same reason. Not sure how he ended up with it he doesn't have a vacuum. May have got it with a tractor he bought??? Share this post Link to post Share on other sites
Kasweld 7 #23 Posted February 21, 2019 1 hour ago, AHenry014 said: Unless my eyes are deceiving me, i spot an extra belt guard NEXT to the factory drive belt guard. The floor board seems to be about a 1/3rd narrower and appears to have a notch cut into it where it angles upward, i would guess for a belt to travel through. Looks like it could guard a belt traveling rearward from one of the PTO grooves. I am definitely no WH guru, but i spot an oddity here! All original as far as I’m aware but I know what you mean Share this post Link to post Share on other sites
Kasweld 7 #24 Posted February 21, 2019 32 minutes ago, WHX22 said: That sucks....Get the numbers off the engine perhaps that will narrow down the year. I’ll get them next time I’m at my unit, thanks Share this post Link to post Share on other sites
Kasweld 7 #25 Posted February 21, 2019 24 minutes ago, Ed Kennell said: Yeah, I see it now. May be Garry will post the file on this. I have never seen one of these and would like to see the pully system to get the drive belt to the rear mounted blower. I’ll try get some more pics of it and show it in more angles for you 1 Share this post Link to post Share on other sites
