carnett@woh.rr.com 2 #1 Posted February 15, 2019 will craftsman 55 lb wheel weights fit on my 520 H 2 Share this post Link to post Share on other sites
pfrederi 19,955 #2 Posted February 15, 2019 Weights for 12 " Garden Tractor wheels are usually interchangeable. Welcome to Red Square 3 Share this post Link to post Share on other sites
WHX?? 55,228 #3 Posted February 15, 2019 Carnett They should fit if they are for 12" rims. Measure across the bolt holes to see if they match up with the 520's. Even if they don't I've saw some of the guys get creative and make adapters. What kinda bike ya perched on there? Share this post Link to post Share on other sites
953 nut 64,322 #4 Posted February 15, 2019 As long as the wheel weights came from the same size rims you will be OK. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,754 #5 Posted February 15, 2019 Here are Sears 55 lb wheel weights that I put on both a 702 and a 416-8. If the rims are shallow, the weights may stick out a bit. If the rims are deeper, then the weights will still fit, but you will need longer bolts. Either way, they will fit. BTW, the 702 has narrow 6 in width rims and my 416-8 has 8.5 inch width rims. A 520 should have 10.5 inch wide rims, so longer bolts will be needed. 4 1 Share this post Link to post Share on other sites
bottjernat1 2,196 #7 Posted February 15, 2019 Yep! should! and welcome to the best place on the web!! Share this post Link to post Share on other sites
SylvanLakeWH 30,640 #8 Posted February 15, 2019 Welcome! they should fit... Share this post Link to post Share on other sites
KC9KAS 4,746 #9 Posted February 15, 2019 @carnett@woh.rr.com to Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,528 #10 Posted February 15, 2019 . . Glad to have you here. Glenn Share this post Link to post Share on other sites
WHX?? 55,228 #13 Posted February 16, 2019 (edited) 8 hours ago, T-Mo said: Here are Sears 55 lb wheel weights that I put on both a 702 and a 416-8. If the rims are shallow, the weights may stick out a bit. If the rims are deeper, then the weights will still fit, but you will need longer bolts. Either way, they will fit. BTW, the 702 has narrow 6 in width rims and my 416-8 has 8.5 inch width rims. A 520 should have 10.5 inch wide rims, so longer bolts will be needed. What's the weight on those Sears ones Terry? They look beefy... Just passed up a set like those on CL just because I found a set of the plastic WH ones on CL. BTW you do know I have a plow day?? We would even let you run the cub! Never mind just re re-read and saw the 55...Don't think the WH ones are that much tho? Edited February 16, 2019 by WHX21 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,754 #14 Posted February 16, 2019 7 hours ago, WHX21 said: What's the weight on those Sears ones Terry? They look beefy... Just passed up a set like those on CL just because I found a set of the plastic WH ones on CL. BTW you do know I have a plow day?? We would even let you run the cub! Never mind just re re-read and saw the 55...Don't think the WH ones are that much tho? I would love to come to one of your plow days, but distance is a real mood killer. I would love to bring my Cub, and if I get either the Cub Cadet 100 going, or one of my WH 953s, I would love to bring one of them also. 1 Share this post Link to post Share on other sites
rk1953 4 #15 Posted April 20, 2019 I have a pair of sears on my WH 520H they weigh 55lbs. Sears wwb site said they would also fit WH But the deep dish rims you will need to get longer bolts than comewith weights. I only used 2 bolts per wheel. Sears makes several sizes so make sure they are for 12 inch rims.Good luck. Share this post Link to post Share on other sites
