dkg520 527 #1 Posted February 14, 2019 I have a 1995 520H that both the fuel gauge and the voltmeter quick working at the same time. The fuel gauge is reading always full even though I have checked the sending unit and that is fine. The voltmeter is getting power but is not working at all. Can I get some advise on where I should start looking for a answer. All other gauges are working fine. Thank you. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted February 14, 2019 8 minutes ago, dkg520 said: I have a 1995 520H that both the fuel gauge and the voltmeter quick working at the same time. The fuel gauge is reading always full even though I have checked the sending unit and that is fine. The voltmeter is getting power but is not working at all. Can I get some advise on where I should start looking for a answer. All other gauges are working fine. Thank you. Need a fuel gauge I have one for a 520h Share this post Link to post Share on other sites
dkg520 527 #3 Posted February 14, 2019 No. That’s not the problem. Thanks Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted February 14, 2019 Could be a ground issue then? 1 Share this post Link to post Share on other sites
dkg520 527 #5 Posted February 14, 2019 That’s what I believe it may be. Any suggest as to where I should start? Share this post Link to post Share on other sites
953 nut 63,096 #6 Posted February 14, 2019 I would suggest you run a new ground wire to the instruments. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted February 14, 2019 How about the sending unit as well? Is that grounded thru the harness? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #8 Posted February 14, 2019 Dash unit. Click on the pictures and again on the page that comes up. Tank unit Garry Share this post Link to post Share on other sites
