Kagnew66 15 #1 Posted February 13, 2019 Will someone please help? I know it's out here, I just can't seem to find it. Thanks. Model Engine Application Size/Part # 701 K161S Starter-Generator belt ?????? Share this post Link to post Share on other sites
stevasaurus 23,568 #2 Posted February 13, 2019 Starter/Generator belt Original Wheel Horse 1583 nla Used on 6, 7, 8hp Kohler Starter generator {3Lx33" in belt charts is 3/8" x 33" but some applications use a shorter belt. Belt should have raw rubber sides for grip.} 3V315 Gates .38"x31.5" 3V315 Napa .38"x31.5" You can find this information in the "Manual's" section. The 701 is a 1961 horse, and I think???this is the one that used 2 belts. 2 Share this post Link to post Share on other sites
Kagnew66 15 #3 Posted February 13, 2019 Thanks. I bought the 3V315 Gates .38"x31.5" , but the package said .38 x 32. Share this post Link to post Share on other sites
rmaynard 16,837 #4 Posted February 13, 2019 (edited) Make sure that the belt is not too long. Even though the starter/generator is adjustable, too long of a belt will cause it and the pulley to rub against the belt cover. Let me check my records and see what size I have on mine. The belts on my 701 are 4L310, and there is not much clearance at the small end of the before cover. Edited February 15, 2019 by rmaynard Added info 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #5 Posted February 14, 2019 The belts were originally supplied with the engine assembly and are Kohler p/n 270415. They're listed as 1/2" wide by 30.5" or 31" long - depending on where you look. https://www.gates.com/us/en/interchange/search/result?part-number=270415 http://outdoorpowerinfo.com/belts/kohler_belts.asp 1 Share this post Link to post Share on other sites
squonk 45,371 #6 Posted February 14, 2019 I use an AX29 notched 31" belt on mine. Share this post Link to post Share on other sites
Kagnew66 15 #7 Posted February 15, 2019 Thanks. I have an engine which came with a 702, and the Gates 3V315 looks like it will fit that fine. The 701, however, has dual pulleys, which are wider (1/2 in.). The belt that's on it is too long to adjust properly. You guys have bailed me out. ***Note : I did try to find some information in the manuals. But frankly, this kind of help is not available in a manual. I appreciate it. Share this post Link to post Share on other sites
WHX?? 54,508 #8 Posted February 15, 2019 On 2/13/2019 at 12:53 PM, stevasaurus said: this is the one that used 2 belts You are correct Dino if the 701 is correct. Share this post Link to post Share on other sites
