bds1984 1,511 #1 Posted February 10, 2019 Over the years I have owned a few Wheel Horses with an Eaton 1100; C195, C175, and a 520H (which I still own). The 520 is primarily a plow tractor which serves me just fine except that it is slow compared to the other two. I understand the difference in ground speed with the C195 is probably due to the larger rear tires on it, not a big deal. Before you ask, yes, I have checked the adjustments of the linkage and what not, I have checked the belt, the fluid and filter were changed within the last year, tires are the same size (23" tall), and it'll push/pull pretty much anything asked of it so I know the pump is not weak. So, let me pick your brains.... why is my 520 noticeably slower than my C175 and C195? Any ideas? Share this post Link to post Share on other sites
lynnmor 8,853 #2 Posted February 10, 2019 The 520HC had gearing for a higher ground speed than the 520H, perhaps someone knows if that is the case with the other tractors you mentioned. Share this post Link to post Share on other sites
