ebinmaine 77,072 #1 Posted February 7, 2019 Both are manual transmissions. Both are manual PTO. I just wasn't sure if the crank size would be the same... ?? Thanks! 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted February 7, 2019 Are they different Hp? I m thinking they are both the same between 2 or 3 inch diameter. Share this post Link to post Share on other sites
ebinmaine 77,072 #3 Posted February 7, 2019 Yeah the c100 is a 10-horse. C-160 is a 16 horse. This is when they were using a larger-diameter engine pulley. Should be 4in OD if I remember right. I just don't know if the crankshaft is the same size. Share this post Link to post Share on other sites
oldredrider 2,553 #4 Posted February 7, 2019 If they are both Kohler engines, they share the same size pulley. 1 1/8" shaft size. 2 Share this post Link to post Share on other sites
ebinmaine 77,072 #5 Posted February 7, 2019 1 minute ago, oldredrider said: If they are both Kohler engines, they share the same size pulley. 1 1/8" shaft size. Yes both Kohler engines. I forgot they put tecumseh in some of those. Share this post Link to post Share on other sites
Marv 994 #6 Posted February 7, 2019 should be the same. If it was an 8 horse it would not. Marv Share this post Link to post Share on other sites
Lee1977 7,544 #7 Posted February 8, 2019 Kohler standard size the K- series same PTO height and the same base mounting 10 HP through 16 HP . All Wheel Horse K- series and Magnum Engines in those HP had 1 1/8" crank shafts. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,978 #8 Posted February 8, 2019 The first 10hp Kohler engines Wheel Horse used had a 1" crankshaft pto shaft. Click on the picture. Garry Share this post Link to post Share on other sites
953 nut 63,947 #9 Posted February 8, 2019 32 minutes ago, Lee1977 said: Kohler standard size the K- series same PTO height and the same base mounting 10 HP through 16 HP . All Wheel Horse K- series and Magnum Engines in those HP had 1 1/8" crank shafts. Some did, some didn't. The 1055(1965) has a 1" shaft and all the rest of my K 241 engines have 1 1/8". 1 Share this post Link to post Share on other sites
