ebinmaine 75,835 #1 Posted February 2, 2019 Getting ready to start painting the engine tins and reassembling the engine for the Cinnamon Horse. I'm going to replace the easy access gaskets such as points cover Etc. Should I, or can I, replace the crank oil seal on the pulley side while I have the pulley off? Share this post Link to post Share on other sites
Marv 994 #2 Posted February 2, 2019 Yes you can. Should you? I would say only if you see some evidence of a leak. Marv 2 Share this post Link to post Share on other sites
ebinmaine 75,835 #3 Posted February 2, 2019 2 minutes ago, Marv said: Should you? Hard to tell because I've had very little time with this engine but the rest of the tractor was very well worn. How does it come out the easiest? Share this post Link to post Share on other sites
Marv 994 #4 Posted February 2, 2019 They are relatively snug in the bore. I have drilled a small hole 180 degrees apart and run a screw into them then pulled with vise grips to remove the seal. Usually works for me. Marv 3 1 1 Share this post Link to post Share on other sites
bds1984 1,506 #5 Posted February 3, 2019 I agree with Marv. I also have a seal puller I got from Sears years ago that works well for that job. 1 Share this post Link to post Share on other sites
iaintavinit 7 #6 Posted March 5, 2019 I've done it. Use a seal puller as stated or a dental pick can work too. Just be careful to get the seal in evenly and you should be ready to go! Share this post Link to post Share on other sites
