Tractorhead 9,209 #226 Posted September 14, 2019 Doing today finally minorworkings. Implementing a High Beam Controll light into Dashboard (last required for road approval) And Fixes the Roof with rubber Dampers. After doing that, i decide to have a longer ride (Testride) I drove into forrest to my Playground, and move my little Mountain i did last testride back to normal. 😂😎 The new roof is a massive improvement, no interference occurs as with the older (Jesus Cross Roof) It is completely silent i just hear the Engine. The FEL seems now completely bleeded. The reaction can now be steered very smoothly and the force is still impressive. Than i try to dig in depth, how good it works, i can diggin 18cm by 1 Shift with 4WD and differential lock. This beast seems to be unstoppable, i love it....👍 😎 after my Testdrive, i went back into Frontyard and check if any troubles occurs. Nothing to see, that can causes Troubles. Back into frontyard, i begin win my further planing of my Hedgecutter Project. Therefore i quickly attached a light Steel rect. Pipe i have in Stock, to see how it will look. i also rethinkin for a Quickmount, for a fast exchange. This is a look from Driverseat, how it will be looked at cutting Sidely a hedge. This pipe is much to weak, i didn‘t plan to use it. It was just for testing and measuring. So it will look if i cut Hedge Top. Simply fixed by 2 Screws seems a acceptable solution. The cutting tilt can be made with FEL also the lift. The setup horizontal or vertical will be made by hand, maybe later via FEL, but that‘s a nice to have for me. Thinkin to build another H Frame with that i was able to construct a quickchanger with a slider, where i be able to enlarge it sideways if needed. 2 Share this post Link to post Share on other sites
Stormin 9,984 #227 Posted September 14, 2019 I don't think you've got enough movement there, Stefan. The blade should cut fully both sides. Mine does. Share this post Link to post Share on other sites
Stormin 9,984 #228 Posted September 14, 2019 27 minutes ago, Tractorhead said: That looks positively lethal, Stefan. I like it! 1 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #229 Posted September 14, 2019 Yap, that looks nicely Dangerous. Hehe but in right hands, this will develop a cool gadget. i‘m compared the Oilmotor and the possibly shift i can use. this Project will also be grown continousely like my Herd. I‘m unsure about Oilpumptest, because i firstly must adapt the Return pipe to a much Thicker diameter. no tube available in needed length. Share this post Link to post Share on other sites
Tractorhead 9,209 #230 Posted September 16, 2019 Time for the Wheelhorse for some Service. I went home and Hermes at same time arrives with the new ordered Clutch. I immediately try to dismount the burned Clutch, but it‘s resited. Then i dismount the whole Shaft from Engine with the clutch, what goes way easier. Open Spanner of Engine belt, let it slip down and try to pry the burned clutch with tender hammer blows arround the clutchbody of. after 5 min, i increases the hammerblows and suddenly - fup- , the clutch was down. i looked at, yap definitely to weak torque, all clutchfriction parts really lights blue.. Than i inserted the new Clutch, what fits niceley and greasing all necessary Parts for Movement and quick mount/ dismount, hinges, splints and levers. Even quick verify and greasing the spindles again while mowerdeck was out, than i looked about sharpness, but they still good. So it becomes dark and i hurry, to mow a bit of the deeper grass, where before the Cluch give up, just to see if my diagnosis was right. Half throttle, full Speed down to the high Grass along the Trees (500m far and back) with med. setup. whilst back, the Engine just play again a bit with the Throttle but not impressive. The Cut was nice, but after i‘m back, i smell a bit weared rubber. ok, it seems the Belt gives now up, no wonder about last thermal Stress. After i‘m stopping the Mowerdeck i touch immediately the Cluch. Cold, just the pulley seems a bit warm, but far from a critical Temp, maybe 30* C thats fine. than, now it‘s dark outside and i mow with Light, i jumped upstairs, grab the torch and take 2 Pics. i know, no Story was happen without evidence... 😂 The new Clutch with now weared Belt Hardly to take a good pict about real height 18cm on left, cutted at once. I think this works well with new Belt again. 3 Share this post Link to post Share on other sites
Tractorhead 9,209 #231 Posted September 17, 2019 Clicking today Mowerdeck off, to see below. As i told, here the new Clutch... and the Status of Mowerdeck... all looks well and pretty sharp. ok, order a new Belt.. 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #232 Posted September 20, 2019 (edited) Yesterday the Belt arrives. firstly i try in a hurry to insert, and wonder Why it will not Fit. Firstly i doubt i‘m made a fail in measuring, but it was allway‘s a good idea, to take some Picts before you disassemble a thing. a simply Fail while wrong insert clears up, where was my mistake. at later night, i review my Picts and found one, where the Belt is shown. I insert it in right direction and the mower fits. i wonder a bit because of stiff spanner, so i get some Gease and bring it back to work. Maybe this was the reason, while the old belt Lasts that quick. However, i try the Mower firstly on slighter grass, later in higher grass. Yes, it works well again. After harvesting my last potatoes, i decide to clean up the Field, but i didn‘t want to do it manually. So i develop a Stupid idea, Why nor use the Wheelhorse, as long as Mowerdeck was out for Cleaning. That was the Rest i can keep for myself.... 😎 Because the neighbours ask for a Try. I‘m proud, they ask me, so it give me the feeling my harvested Result can not be Bad. i spend some and keep for us just 3,5 Kilos. The complete Harvest was now all together 28Kilo by inserted 5 Kilo. Anyway, Than i search for few Quickstraps and bound my Manual Tiller onto my FEL. So i can do the Job while having some Seattime on my beloved Horse. I wanna move the Beast, while it‘s prepared for Road Approval. Done as Sayed, i fiddeling it onto. and it looks funny, but i tryed it if this will work. i did a small Video, to show how it works, think i have to build a simple Leversystem, that i can mount it quickly and stiffer, but it does it‘s work better than i expected. i needs several passes, because our Soil iv very clayley. but after 5 Passes, i satisfied with the Result. 865C2EB0-9104-44E1-9241-0534B8D67221.MOV Edited September 20, 2019 by Tractorhead 2 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #233 Posted September 21, 2019 Today i get a Buddy’s Trailer, now we will be prepared for Road Approval. Curious what they Meant. The guy with whom i talked all about, was not able to do, because he’s out of Order by Family, so a Collegue of him make the Approvals. i hope that‘s a good Sign. I feel like in the School, short before Test was out. 2 Share this post Link to post Share on other sites
Pullstart 66,609 #234 Posted September 21, 2019 Stefan, we were in Munich airport this morning! Wish there was a way to say hi then... but we were in a layover. Prost! 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #235 Posted September 23, 2019 Buddy, 😱 Too Bad, if i kew this before, i went early to Airport for a Hello Face to Face. We are leaving very early tomorrow 4:00 AM for 2 Weeks Holiday‘s. 😢 1 Share this post Link to post Share on other sites
Pullstart 66,609 #236 Posted September 23, 2019 Enjoy your trip Stefan... just drop me your address and I’ll tend your herd while you’re away! Cheers! Share this post Link to post Share on other sites
Tractorhead 9,209 #237 Posted September 23, 2019 Sounds interesting... 😂 so i know, the poor herd is in good hands. I GOT IT Yeeeeeehaaaaaaa! Road approval was a Success ! Yessssssss👍 I just have to bring them a Weight protocol for Paperworks, what i make after our Holiday. i asked them, and i was allowed, to take a Pict at Check Station. i just have to blank all Licenseplates on Pict. I‘ll be Proud of it. 1 Share this post Link to post Share on other sites
Stormin 9,984 #238 Posted September 23, 2019 2 hours ago, Tractorhead said: 2 hours ago, Tractorhead said: I GOT IT Yeeeeeehaaaaaaa! Road approval was a Success ! Yessssssss👍 I just have to bring them a Weight protocol for Paperworks, what i make after our Holiday. Well done, Stefan. Couldn't help but laugh at the test depot sign. 2 hours ago, Tractorhead said: 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #239 Posted September 23, 2019 It depends a few seconds, that i realize it...😂😂😂😂😂 Share this post Link to post Share on other sites
Tractorhead 9,209 #240 Posted September 28, 2019 Yesterday, we did a bit island hopping in greek. Chartered a small Boat for a whole Day and have some Fun with. We found several hidden Beaches, mostly with gravel, but they invite to Stay for a Break. 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #241 Posted October 8, 2019 Back from holiday, i finalized the Roadapproval with a Weightprotocol. I must do, because the FEL was now a fixed Part of the Tractor. prepare the scale... front Axle and Rear Axle Tells, the collected Weight of FEL all together was 74 Kilos. the rest was the 3Point rearlift. (8 kilos) Done. Just have to wait, until Paperwork is finalized. 1 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #242 Posted October 11, 2019 Firstly i do some Seattime on my Horse, to mow the Lawn. 👍 After i control weight yesterday with the Shovel mounted, i know now, i have exactly 340Kilos on the Frontaxle. And 277 Kilos on the Rearaxle. The Anglepoint of my FEL was exactly at the center of my Rearaxle, what can handle up to close a Ton of Weight. that seems enough for my Tests, so i feel comfortable with. With that knowledge i tryed today, to change the Palette under the Agave. I organized a newer Palette and mount some Tyres below, that she can be easy moved by hands. To do this, i firstly lift her a bit and build a construct to stabilize and drive under the old broken Palette, after that i try to move her out of the Frontyard. That stoppen at the curbs, just the Tractor lifts front legs...😱😎 After a first Try, where the Beast lift the Frontaxle and i must keep front tyres back on floor, so i must put some weight in the Shovel, otherwise i have nearly no pressure on the Frontwheels. I was simply able to lift the frontaxle nearly with just bit force under Shovel - easy to do. Ok it rains the last 2 Day‘s, that means that Beast of Flower has a overall weight now of about 320 Kilos. 😳 Damn heavy- i guess it was much easier, but it wasn't. just after put +30Kilos in the Shovel i can drive with her on the Backfork. Impressive was, the FEL has absolute no problem to lift her, even without added balance weight on rear. it was also very stable, so i can carefully drive with her in the FEL. All last and work as calculated and as expected. I‘m happy with my build. 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #243 Posted October 23, 2019 (edited) Finally i made it.. Today after Doctor i went in registration office and.... Roadlegal - yeah, ok somebody will hate me, if i drove on the Road, 😂 but it was just a huge Goal for me, to solve that. 😎 it ain‘t easy looks bit better with it‘s own Lizence plate. Winter, you can come, i be prepared... even if a Policecar comes along... Edited October 23, 2019 by Tractorhead 3 Share this post Link to post Share on other sites
Tractorhead 9,209 #244 Posted November 10, 2019 (edited) Reworked several issues Firstly i reworked the Plowshield, while it was last year to weak, and the Beast pushes too hard. After the whole Mountingbrackets rips, i improved all a bit stiffer, and reworked the Protectsprings for the Plowshield to do a safe job. the lift will now be handled with the FEL on my Horse. we will see if it lasts this year, pushing Leaf was a success. Than i decided to rework an old Pavillion as a small cabin for the Winter on the Beast. not pretty nice, but it will work for now. a pretty cool issue was, that the Cooling temp of the Engine passes the Cabin and will act as heater. while hedgecutting, i was able to test it. Windshield was free, just a wiper will be built later on to remove snow. but actually, it works pretty nice. i decided to leave it without paint, as long as all worked as needed. If it develops a bit of rust, i can deal with next year. moving parts are greased and the rest, we will see After i collected the Leaf, i had the Horse in Frontyard and can do some work on heavy things without moving anything by hands. So i can rework the Hedgecutter Project. it will be screwed under the Shovel of the FEL and can be extended about 1 meter sideway‘s. The first try shows me the shiftmechanism was a bit to weak, but it works. so i reworked the Mechanism to increase the stability. a cut of 2cm thick hedge is now no more a Problem and all works as expected. the only thing i must change was the lines, they will be changed to 90* connectors, if delivered. but it works nice and smooth. so Gentlemen, Winter can come, i‘ll be prepared... Edited November 10, 2019 by Tractorhead Added comments 2 1 Share this post Link to post Share on other sites
Stormin 9,984 #245 Posted November 11, 2019 Good re-use of the gazebo, Stefan. 1 Share this post Link to post Share on other sites
Tractorhead 9,209 #246 Posted November 11, 2019 Finalized a bit more... finetuning is done on the Lines... now i can also mow the Grass if needed, or maybe Snow...😂 1 2 Share this post Link to post Share on other sites
Tractorhead 9,209 #247 Posted November 13, 2019 Fired quick the Laser, to do a Test it was unused after 6 months periode, so cleanup all, change Cooling Water and try... back in Service again... 1 2 Share this post Link to post Share on other sites
Pullstart 66,609 #248 Posted November 13, 2019 I see the darker wheel on your test piece, that’s a cool machine! Stefan that patio cover looks like it will work awesome! Share this post Link to post Share on other sites
Pullstart 66,609 #249 Posted November 13, 2019 I missed the last post on the finalized trimmer, WE WANT VIDEOS! of you trimming the snow! Share this post Link to post Share on other sites
Tractorhead 9,209 #250 Posted November 13, 2019 3 hours ago, pullstart said: I missed the last post on the finalized trimmer, WE WANT VIDEOS! of you trimming the snow! I would try, but it doesn‘t snow enough... still wait for an Snow- Upgrade.. 😂😎 Share this post Link to post Share on other sites
