The Tuul Crib 7,339 #1 Posted January 27, 2019 Pulled my 1987 414-8 out of the garage this afternoon to make sure everything was in working order because we may get snow on Tuesday here. Engine idols fine and has an adjustment to fix that but at high rpm's it sputters and cannot find an adjustment screw for that any suggestions would be helpful. Share this post Link to post Share on other sites
Digger 66 3,488 #2 Posted January 27, 2019 How old is the fuel ? Share this post Link to post Share on other sites
The Tuul Crib 7,339 #3 Posted January 27, 2019 14 minutes ago, Digger 66 said: How old is the fuel ? Not that old but I pulled the bowl of the carburetor and found a bunch of junk in the bottom of it so I cleaned it out hopefully that will help. Share this post Link to post Share on other sites
wallfish 18,460 #4 Posted January 27, 2019 9 minutes ago, The Tool Crib said: pulled the bowl of the carburetor and found a bunch of junk in the bottom of it so I cleaned it out hopefully that will help. It's probably a fixed jet carb with no adjustment needle for the high speed. If you had "a bunch of junk" in the bowl then there's a bunch of junk in the carb. A thorough cleaning of the entire carb and you should be all set 5 1 Share this post Link to post Share on other sites
wildman 205 #5 Posted January 28, 2019 Would be a good time to swap out the fuel line 2 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #6 Posted January 28, 2019 2 hours ago, wallfish said: It's probably a fixed jet carb with no adjustment needle for the high speed. If you had "a bunch of junk" in the bowl then there's a bunch of junk in the carb. A thorough cleaning of the entire carb and you should be all set As well as the fuel filter! 1 Share this post Link to post Share on other sites
pfrederi 18,810 #7 Posted January 28, 2019 I really am not impressed with the Walbro Fixed jet carbs. If they act up I tend to by a Chinese knockoff with the adjustable main 1 Share this post Link to post Share on other sites
