CrazyDetroit 7 #1 Posted January 25, 2019 (edited) I found this starter on Amazon will this starter work im concern about the end shaft. I would like to put factory back on short on cash..ty again.Im looking for starter information i see a few different brands on internet which on is best. C160 number on my starter is ...smh 12 a 201 American bosch. Factory orignal. 48 years not to bad for a starter life. It was so cold out shaft snapp off... second problem rear end freezes up will not shift until warmed up for 30 minutes showing oil on dip stick a little brown could this be water in rearend casing. Edited January 25, 2019 by CrazyDetroit Added pics Share this post Link to post Share on other sites
tunahead72 2,554 #2 Posted January 25, 2019 12 minutes ago, CrazyDetroit said: ... second problem rear end freezes up will not shift until warmed up for 30 minutes showing oil on dip stick a little brown could this be water in rearend casing. Yes, if this is an 8-speed manual (I can't speak for hydros, at all). Your trans. fluid could be freezing and causing your problem. Can you get your tractor into a warmer area before you try to drive it next time? And if it hasn't been done in a while, it would be a good idea to drain and flush and replace your trans. fluid. Also, check the rubber boot around the gearshift lever, and replace that if it's at all damaged, that's probably where water is getting into the trans. 6 Share this post Link to post Share on other sites
Ed Kennell 42,226 #3 Posted January 25, 2019 1 hour ago, CrazyDetroit said: which one is best. ...smh 12 a 201 American bosch. Factory orignal. 48 years not to bad for a starter life. I think you answered your own question. 2 Share this post Link to post Share on other sites
stevasaurus 23,307 #4 Posted January 25, 2019 I always start my horse with the clutch pushed in...for one thing, it eases the drag on the started...for another, if it is winter and your trans is froze, you can start your horse and slowly let out the clutch. If it is froze you will kill the engine, not the starter. 1 Share this post Link to post Share on other sites
WHX?? 51,920 #5 Posted January 25, 2019 8 hours ago, tunahead72 said: it would be a good idea to drain and flush and replace your trans. fluid. Real good idea! Share this post Link to post Share on other sites
CrazyDetroit 7 #6 Posted January 25, 2019 Ty for the help on trans. I been using a 250k jet heater to warm up trans until spring. Shifter boot leaking ty never thought of that. Share this post Link to post Share on other sites
953 nut 60,405 #7 Posted January 25, 2019 When you get around to changing the transmission oil be sure to jack up the front end so it will drain completely. Share this post Link to post Share on other sites
