timo4352 148 #1 Posted January 25, 2019 I have had a chance to plow a few times now with the new tri ribs on the front of my horse and just have to say that they are amazing in the snow. I had my doubts before, but after using them I am a believer. Awesome upgrade. 10 Share this post Link to post Share on other sites
Lee1977 7,644 #2 Posted January 25, 2019 We like pictures. Some of the Wheel Horse in the snow. 1 1 Share this post Link to post Share on other sites
bc.gold 3,406 #3 Posted January 25, 2019 59 minutes ago, timo4352 said: I have had a chance to plow a few times now with the new tri ribs on the front of my horse and just have to say that they are amazing in the snow. I had my doubts before, but after using them I am a believer. Awesome upgrade. I installed new tri-rib tires onto the fronts of my Simplicity 9020 they handle great and I find the steering effortless. The ribbed tires also have a higher profile than the wider front tires that came with an Allis 720 that I had added t my collection of old tractor. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #4 Posted January 25, 2019 20 minutes ago, Lee1977 said: We like pictures. Some of the Wheel Horse in the snow. Share this post Link to post Share on other sites
ebinmaine 79,173 #5 Posted January 25, 2019 3 hours ago, timo4352 said: I have had a chance to plow a few times now with the new tri ribs on the front of my horse and just have to say that they are amazing in the snow. I had my doubts before, but after using them I am a believer. Awesome upgrade. As with the others I of course would love to see some pics. Curious to know what size you have and if they are weighted or fluid-filled or anything like that? Share this post Link to post Share on other sites
timo4352 148 #6 Posted January 25, 2019 I have 4.00 x 8 tri ribs on my 310-8. A step up from the 6 inch wheels. No fluid filled. I do have about 25 pounds of steel tucked up inside the frame in front. I run the stock narrower turf tires 22 x 7.50 x 12 in the rear with WH plastic weights and chains. pics soon Share this post Link to post Share on other sites
cafoose 3,736 #7 Posted January 25, 2019 I'm actually thinking of tri ribs on my 876 that I primarily use with a blade. I'd like to get an extra set of wheels to put them on. What other tractors have the same wheels as my 876? Share this post Link to post Share on other sites
Firebug 267 #8 Posted January 25, 2019 What wheels did you use on the 310-8? Any differences in the width over the stock rim Share this post Link to post Share on other sites
Lee1977 7,644 #9 Posted January 25, 2019 (edited) The 400 x 8 works better on a 3 or 4" wide wheel. I used Wheel Horse trailer wheels, but we had to chuck them in the lathe and cut 3/4" of the hub to get them to fit. Front WH tractor wheels measure 3 3/4" through the hub with the bearings installed. Edited January 25, 2019 by Lee1977 1 1 Share this post Link to post Share on other sites
Firebug 267 #10 Posted January 25, 2019 I hear that is the common switch to use the trailer wheels. I’m inthe market for a pair for that reason Share this post Link to post Share on other sites
timo4352 148 #11 Posted January 25, 2019 My wheels are really narrow -- like 2-1/2 or 2-3/4...I kinda forget which. IFRC they came off a Gravely snowblower, maybe? You will see when I get those pics up... I think the tires look just right on the narrow wheel. But a wheelbarrow wheel could work. Think they are more in the 3 to 4 inch range though. Share this post Link to post Share on other sites
wallfish 20,053 #12 Posted January 25, 2019 Poor man's tri rib is wrapping #40 roller chain around the front tires. Install them tight around the center on a deflated tire, add air to tighten them up. Deflate again to remove if needed. It's done on ALL my snow machines and significantly reduces front slide for plowing or blowing. 3 1 Share this post Link to post Share on other sites
timo4352 148 #13 Posted January 25, 2019 When I got my tri ribs on ebay they were 26 bucks for a pair - yes 13 bucks each. I could not believe it, and jumped on the deal. That deal didn't last long but they are still pretty darn cheap. Simple Tire was the seller. Share this post Link to post Share on other sites
timo4352 148 #14 Posted January 26, 2019 Not much snow to plow today. About an inch or so to scrape off. But you wanted some pics, so here ya go... 1 Share this post Link to post Share on other sites
Lee1977 7,644 #15 Posted January 26, 2019 Looking good. Tri-ribs, stack with rain cap to keep you awake in that warm cab. Share this post Link to post Share on other sites
