BHunter 1,700 #1 Posted January 22, 2019 I just put a lot of hours in this blade. I removed all the pieces , sand blasted, then applied epoxy primer and paint. Then I bought some round stock and replaced the extremely worn out pins. It was worth all the work. It’s good for another 60 yrs now. 1 10 1 Share this post Link to post Share on other sites
Pullstart 68,181 #2 Posted January 22, 2019 Great work! Yeah those pins look a little bit shot. 1 Share this post Link to post Share on other sites
BHunter 1,700 #3 Posted January 22, 2019 1 minute ago, pullstart said: Great work! Yeah those pins look a little bit shot. Thanks. Yes they were. There was a lot of extra movement in the brackets. 1 Share this post Link to post Share on other sites
ebinmaine 74,572 #4 Posted January 22, 2019 Looks fantastic sir. Did you do anything with the holes that those pins went into or were they okay? Share this post Link to post Share on other sites
BHunter 1,700 #5 Posted January 22, 2019 13 minutes ago, ebinmaine said: Looks fantastic sir. Did you do anything with the holes that those pins went into or were they okay? Thank you. The holes were ok. I thought I was going to have to weld them up but the new pins fit good. 1 1 Share this post Link to post Share on other sites
BHunter 1,700 #6 Posted January 22, 2019 19 minutes ago, ebinmaine said: Looks fantastic sir. Did you do anything with the holes that those pins went into or were they okay? Snug fit. Looks like texture paint but it’s rust pits. It must have spent its entire life outside. 4 Share this post Link to post Share on other sites
WHNJ701 4,166 #7 Posted January 22, 2019 Looks great ,when is it getting mounted? Share this post Link to post Share on other sites
BHunter 1,700 #8 Posted January 22, 2019 26 minutes ago, jabelman said: Looks great ,when is it getting mounted? Thanks. Hopefully before the next snow storm. If we ever get one this year Share this post Link to post Share on other sites
WHNJ701 4,166 #9 Posted January 22, 2019 26 minutes ago, BHunter said: Thanks. Hopefully before the next snow storm. If we ever get one this year I would be happy if I never see snow again 1 Share this post Link to post Share on other sites
BHunter 1,700 #10 Posted January 22, 2019 38 minutes ago, jabelman said: I would be happy if I never see snow again Me too . It creates a lot of extra work for me to do. We’ve got lucky so far this year. 1 Share this post Link to post Share on other sites
Achto 29,848 #11 Posted January 23, 2019 Super work!!! I'm would really like to have a down draft booth like that!! 1 Share this post Link to post Share on other sites
BHunter 1,700 #12 Posted January 23, 2019 49 minutes ago, Achto said: Super work!!! I'm would really like to have a down draft booth like that!! Thanks. It’s nice. No dust in paint and you almost don’t need to wear a mask. The over spray gets sucked right down. 2 Share this post Link to post Share on other sites
Achto 29,848 #13 Posted January 23, 2019 1 minute ago, BHunter said: No dust in paint and you almost don’t need to wear a mask. The over spray gets sucked right down. Much, much better than a box fan in the window. 1 Share this post Link to post Share on other sites
BHunter 1,700 #14 Posted January 23, 2019 1 minute ago, Achto said: Much, much better than a box fan in the window. For sure. It’s so nice to be able set the temp on 75 when it’s 20 degrees outside and lay out a beautiful paint job. Then crank up the temp to 140 and cure the paint . Dry to the touch in 40 minutes. 1 3 Share this post Link to post Share on other sites
oliver2-44 10,977 #15 Posted January 23, 2019 I too would like to have access to a great paint booth like that! 1 hour ago, Achto said: Super work!!! I'm would really like to have a down draft booth like that!! 1 Share this post Link to post Share on other sites
