Cetan08 311 #1 Posted January 11, 2019 I am being lazy today so trying to avoid going to the garage in the cold. Does the same pulley wh 7466 that fits on the K-341 also fit on the BF MS Onan. I have looked at several files and cannot find the shaft sizes and can only find the pulley listed on the tractor with the K-341. I probably missed it. I did say that I am being lazy today. 😁 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #2 Posted January 11, 2019 Seems to me the crank diameter is the same if that's what you mean.See if anyone else agrees. I could be wrong. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,285 #3 Posted January 11, 2019 The 1974-1975 D-160 Automatic with a K341 used a manual pto clutch unlike anything else Wheel Horse used.The pulley is not 7466. https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/1-0650-d-160-toro-d-160-automatic-tractor-1974/p-t-o-clutch-cont-d/ The BF MS was used on the 1976-1978 D-160 Automatic tractors and did not use a stand-alone engine pulley. They used an electric clutch to drive the attachments off the pto end of the crankshaft and drove the transmission off the flywheel end. https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/61-16os01-d-160-toro-d-160-automatic-tractor-1976/p-t-o-clutch-d-160/ In applications where the 7466 was used the transmission determined the OD sizes of the engine pulley and the transmission pulley. Hydro's are different OD. B&S engines, 8hp engines and early 10hp tractors used a 1" crankshaft. All others used 1-1/8" crankshaft. On the D-Series I don't know the crankshaft pto end diameter. Garry 1 Share this post Link to post Share on other sites
