peter lena 9,770 #1 Posted January 3, 2019 just refitting areas on a recent magnum 12 engine swap, is there a slightly larger , HOUSING ROD to pto clutch area ? using the existing ,upper engine bolt on frame , and the lower chassis rod hole, the rod barely hangs on the lower hole and tight fits top of pto pulley clearance. I am using a 1982 " c " chassis , but don't recall ever having a rod housing problem. same shape rod / design but its short to fit either end , any ideas or answers? thanks for a reply , Pete Share this post Link to post Share on other sites
pfrederi 19,911 #2 Posted January 3, 2019 There are different part numbers 300/400 singles used one the twin cylinder a different one. C series used two different part numbers also one for single one for twins. 1 Share this post Link to post Share on other sites
953 nut 64,140 #3 Posted January 3, 2019 5 hours ago, peter lena said: HOUSING ROD to pto clutch area ? using the existing ,upper engine bolt on frame , and the lower chassis rod hole, the rod barely hangs on the lower hole and tight fits top of pto pulley clearance. A couple of pictures might be helpful in coming up with a solution. Share this post Link to post Share on other sites
peter lena 9,770 #4 Posted January 5, 2019 after looking for this with available information , I came upon the best picture and answer https://www.ebay.ca/itm/Wheel-Horse-pto-hoops-lot-of-seven/143075814531?hash=item214ffbac83:g:bLUAAOSwt~5biuzZ:rk:5:pf:0 . model / year only confuses the issue, measure what you need , and put it up against what is out there. I needed another 1, 1/2" on the lower end , for lift and clearance. unless you get an original set up, you will have to adapt to what works. pete Share this post Link to post Share on other sites
