richmondred01 2,333 #1 Posted December 23, 2018 Added 52 pounds of weight to the inside of the wheels. It slipped a few times last snow and I’m thinking this will help. 7 5 Share this post Link to post Share on other sites
Lee1977 7,551 #2 Posted December 23, 2018 How much weight total in each wheel? Share this post Link to post Share on other sites
richmondred01 2,333 #3 Posted December 23, 2018 66 pounds per wheel. 132 total. Ill see how it does. I can always add an additional 50 pounds or so to the clevis hitch Share this post Link to post Share on other sites
ebinmaine 77,309 #4 Posted December 24, 2018 .... And fluid fill 1 Share this post Link to post Share on other sites
richmondred01 2,333 #5 Posted December 24, 2018 I’m not a fan of loaded tires. 1 Share this post Link to post Share on other sites
ebinmaine 77,309 #6 Posted December 24, 2018 6 minutes ago, richmondred01 said: I’m not a fan of loaded tires. Curious to know why. Have you had a bad experience with them? Share this post Link to post Share on other sites
WHNJ701 4,169 #7 Posted December 24, 2018 no chains? Share this post Link to post Share on other sites
richmondred01 2,333 #8 Posted December 24, 2018 I have some chains. Didn’t use them this year because they made marks on the neighbors driveway last year. fluid in tires....I’ve replaced several rims because of rust in the past. I also swap turf tires with lugs in the winter. Putting them on my tire rack is difficult. 1 Share this post Link to post Share on other sites
GlenPettit 1,718 #9 Posted December 24, 2018 (edited) Lug tires don't really need chains if you're careful and have lots of weight, I've added 200# per rear tire and have no problems, = just great traction. Don't forget if you add a lot of weight on the rear axle, add some to the front for steering control, (when adding # to the rear, you're lightening the front slightly). To de-rust chain, put it in a quart of white vinegar in a bucket with a quart of water (50-50%) let sit 1-2 days (in basement), then put chain in a bucket with old oil. Good Luck, Glen Another thought is Rubber Tire Chains I use them and have been very happy with the results, my first choice is Lug tire without chains, I have a long asphalt drive with slight hills. Google Amazon and look for Rubber Tire Chains, but add extra rubber cross links for a much smoother ride. Not the best on smooth ice. A product called "RIMGUARD" is what the professionals use, will not rust nor hurt the enviroment, wherever Farmers go is who has it. Filled tire prices can be all over the place so shop around, I pay about $30 for rears, $20 for fronts, total, using good tires/rims and/or tubes is smart to reduce leaks. Done right they won't leak. Regular Window Anti-Freeze can break-down chemically over the years, (the alcohol in it is what changes) . RIM-GUARD will last for decades and is completely organic (google it). Edited December 27, 2018 by GlenPettit 3 1 Share this post Link to post Share on other sites
WHNJ701 4,169 #10 Posted December 24, 2018 one of the old guys used to run his ag lugs backwards for snow Share this post Link to post Share on other sites
pfrederi 19,873 #11 Posted December 24, 2018 (edited) 1 hour ago, jabelman said: one of the old guys used to run his ag lugs backwards for snow That was so he could back out of trouble. Ags are near worthless backing up. If you are plowing snow and get stuck you usually want to back out the way you went in. When you raise the blade to back up you lighten the rear of the tractor making backing up with Ags even more difficult. Many farmers with 4 wheel drive tractors will mount the front Ags backward to get better traction backing up (backing a loaded manure spreader if it is sinking in can be a challenge even with 4wd.) Edited December 24, 2018 by pfrederi Share this post Link to post Share on other sites
squonk 45,492 #12 Posted December 24, 2018 Fluid filled are the bomb! I use RV antifreeze with anti-corrosion inhibitors. The momentum of the fluid spinning helps push the tractor when it gets bogged down. 2 Share this post Link to post Share on other sites
Pullstart 68,865 #13 Posted December 27, 2018 On 12/24/2018 at 9:01 AM, GlenPettit said: Lug tires don't really need chains if you're careful and have lots of weight, I've added 200# per rear tire and have no problems, = just great traction. Don't forget if you add a lot of weight on the rear axle, add some to the front for steering control, (when adding # to the rear, you're lightening the front slightly). To de-rust chain, put it in a quart of white vinegar in a bucket with a quart of water (50-50%) let sit 1-2 days (in basement), then put chain in a bucket with old oil. Good Luck, Glen Another thought is Rubber Tire Chains I use them and have been very happy with the results, my first choice is Lug tire without chains, I have a long asphalt drive with slight hills. Google Amazon and look for Rubber Tire Chains, but add extra rubber cross links for a much smoother ride. Not the best on smooth ice. A product called "RIMGUARD" is what the professionals use, will not rust nor hurt the enviroment, wherever Farmers go is who has it. Filled tire prices can be all over the place so shop around, I pay about $30 for rears, $20 for fronts, total, using good tires/rims and/or tubes is smart to reduce leaks. Done right they won't leak. Off topic I know, but so good to see you on Glen! I recal you treating my little girls to pencils, stickers and whatnots at Scott’s show in Indiana, now they have their own tractors! I hope all is well, and Merry Christmas! 2 Share this post Link to post Share on other sites
