moe1965 774 #1 Posted December 15, 2018 Hello all I'm trying to find O rings for a 5025 trans. Axle , input, and the left side where the break drum is. I looked at a few threads and was unable to come up with any part numbers Thanks in advance. Share this post Link to post Share on other sites
WHX?? 55,192 #2 Posted December 15, 2018 Axles & brake shaft is a SKF 9815 Input is a SKF 7410. Any NAPA will be able to get them. They are properly called seals. If you go to the index in transmissions you will find a pinned thread that Stevasaurus graciously made up with bearing/seal charts for the popular transmissions. The second one lists the parts for a 5025. 2 Share this post Link to post Share on other sites
moe1965 774 #3 Posted December 15, 2018 Thanks WHX21 my bad on asking for O rings and not oil seals. I'm still not able to find the index you are talking about. I know all the info is out there and I hate to keep asking people for the info I should be able to find on my own. Thanks again Moe Share this post Link to post Share on other sites
WHX?? 55,192 #4 Posted December 15, 2018 No big deal Moe, we get not everyone can navigate here as well as others. I always have a problem finding stuff on here I know I saw once https://www.wheelhorseforum.com/forum/49-transmissions-and-transaxles/ Fourth thread down from the top. That's where you will find this. UNI DRIVE TRANS 2.pdf 1 Share this post Link to post Share on other sites
WHX?? 55,192 #5 Posted December 15, 2018 All the threads at the top with a green thumb tack are pinned threads that will always be at the top of each section so they are easy to find and always packed with good Horse info. Hope this helps. 1 Share this post Link to post Share on other sites
