Guy E. Myers 3 #1 Posted December 9, 2018 Does anyone have a diagram of the breather assy. I was checking valve adjustment and dropped mine . Not sure if I have it assembled correctly. Not sure if I am labeling it correctly. Thanks Share this post Link to post Share on other sites
Lee1977 7,544 #3 Posted December 9, 2018 (edited) Starting at the block there is a rectangular gasket then a metal plate with three hole the formed area toward the engine then a reed breather then a baffle breather with a filter with a rubber tube sealer another gasket with center bar and then the metal cover. I am guessing you have a Kohler engine. Edited December 9, 2018 by Lee1977 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,980 #4 Posted December 9, 2018 https://www.partstree.com/parts/kohler-engines/engines-horizontal/k341-71141-kohler-k341-engine-k-series-wheel-horse-16hp-11-9kw-specs-71105-71384/breather-vent-3-16-2-tp-983-b-rev-9-22-2006/ Garry 1 1 Share this post Link to post Share on other sites
Guy E. Myers 3 #5 Posted December 11, 2018 Thank s for the info on the valve breather assy. I thought I had it assembled correctly but wasnt sure Thanks again for the help. Sorry I dont know how to do pictures. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #6 Posted December 11, 2018 4 minutes ago, Guy E. Myers said: Thank s for the info on the valve breather assy. I thought I had it assembled correctly but wasnt sure Thanks again for the help. Sorry I dont know how to do pictures. When you get done with your post go to the bottom where it says click to choose files. That should send you to your photo list and then you choose the photos . Share this post Link to post Share on other sites
