rdeanrj58 68 #1 Posted December 7, 2018 Does anyone know if Matt is still selling hydro pedal kits ? I sent him a message over a week ago and haven't heard from him Share this post Link to post Share on other sites
cschannuth 3,819 #2 Posted December 8, 2018 I bought one from him last spring when he had them on sale. I don't know if he's still doing them. Share this post Link to post Share on other sites
rdeanrj58 68 #3 Posted December 8, 2018 Yes Matt did reply. Unfortunately his kit will not work on my older tractor Share this post Link to post Share on other sites
peter lena 9,769 #4 Posted December 8, 2018 how much of a change would you have to make , to adapt it ? pete Share this post Link to post Share on other sites
rdeanrj58 68 #5 Posted December 8, 2018 I have a 1973 14auto. Matt said he hasn't put it on anything older than a 1977 C-160. He said that wasn't easy. I'll probably just try to get used to my center mounted shifter. I don't like that it's not spring loaded . Hard to get used to Share this post Link to post Share on other sites
Pullstart 68,887 #6 Posted December 8, 2018 37 minutes ago, rdeanrj58 said: I have a 1973 14auto. Matt said he hasn't put it on anything older than a 1977 C-160. He said that wasn't easy. I'll probably just try to get used to my center mounted shifter. I don't like that it's not spring loaded . Hard to get used to Does the brake pedal return to neutral on that tractor? Share this post Link to post Share on other sites
rdeanrj58 68 #7 Posted December 8, 2018 Yes it does Share this post Link to post Share on other sites
cschannuth 3,819 #8 Posted December 9, 2018 I don't think you'd like a hand control with spring return. You'd have to hold the lever all the time to move the tractor. 1 Share this post Link to post Share on other sites
paxz71usa 173 #9 Posted December 9, 2018 Hello rdeanrj58, I have a 73 12 Automatic and once I got used to the center shifter its nice to operate. You are right though it does take a little getting used to. I have a friend I work with that has a newer WH with hand control and he has to hold it all the time to mow or what ever he's doing. Not sure if that's the way they all are or just his. Seems like a real pain to me. I'll keep the center stick! Gary Share this post Link to post Share on other sites
Sarge 3,470 #10 Posted December 9, 2018 Just fyi - if you don't like the '73 center mounted direction control it can be converted to the earlier/later style long arm next to the dash - you just need those parts from the other years. The biggest difference is the motion control frame that sits in the center tunnel which controls the hydro transmission. That part can be tricky to change, but it's been outlined here many times on how to get it apart without destroying it. Sarge 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #11 Posted December 9, 2018 11 hours ago, paxz71usa said: I have a friend I work with that has a newer WH with hand control and he has to hold it all the time to mow or what ever he's doing. Not sure if that's the way they all are or just his. Seems like a real pain to me. I'll keep the center stick! Gary No that shifter linkage needs adjusting, after a good cleaning (and maybe even disassembly) the friction washer (may even need replacing) needs adjusted to where it actually holds where there lever is moved to its kinda a PITA but doable, (I've owned my anniversary since new I don't have to hold the lever) and NO liquid or paste lubrication on the friction joint, Jeff. 1 Share this post Link to post Share on other sites
rdeanrj58 68 #12 Posted December 10, 2018 Thanks for all the ideas. I think l'll keep it original for now and try to get used to it. I've gotten so used to my Ford LGT 18 with a foot pedal that it's hard to get used to something else. I also have an 875 and a 1276 that aren't running but may be future projects. May need some advice on getting them going Share this post Link to post Share on other sites
redone 45 #13 Posted December 13, 2018 I am searching for foot rest on my charger automatic. Both sides. As I look for these foot rest, they have holes in the pan. Any idea who has these? Share this post Link to post Share on other sites
rdeanrj58 68 #14 Posted December 13, 2018 I would try A-Z Tractor in Pennsylvania. You can find them in the vendor section here on Red Square or search A-Z Tractor on Google Share this post Link to post Share on other sites
RJR49 159 #15 Posted December 14, 2018 (edited) It's actually easier to put Matt's pedal on an older tractor, because there's no dissassmbly. I have one on a 1975 C-160 and it works great! I'll post a picture when I get back to work. RS won't let me post one from my phone Edited December 14, 2018 by RJR49 Extrs Share this post Link to post Share on other sites
rdeanrj58 68 #16 Posted December 14, 2018 Thanks. I would appreciate that Share this post Link to post Share on other sites
