Gospelsinger91 15 #1 Posted December 2, 2018 I am going to restore my Wheel Horse 1057 tractor. I noticed that the Engine "color" was really close to some of the GM motor paint. Does anyone know the correctpaint color and/or name? Thanks, Tommy Share this post Link to post Share on other sites
AMC RULES 36,945 #2 Posted December 2, 2018 International Harvester Red. 1 Share this post Link to post Share on other sites
oliver2-44 8,853 #3 Posted December 2, 2018 Some of us use rustoleum Regal Red. Ford high heat engine red is a very close match to Regal Red Share this post Link to post Share on other sites
pacer 3,159 #4 Posted December 2, 2018 Hah, paint is one of those things that seems to be used in quite a range of reds! -- as you are already seeing in these few replies! IE: I, for some forgotten reason, started out using Rustoleum red -- and, yes I even use it on the engines, and surprisingly holds up pretty well... Share this post Link to post Share on other sites
WHNJ701 4,164 #5 Posted December 2, 2018 9 hours ago, pacer said: Hah, paint is one of those things that seems to be used in quite a range of reds! -- as you are already seeing in these few replies! IE: I, for some forgotten reason, started out using Rustoleum red -- and, yes I even use it on the engines, and surprisingly holds up pretty well... for all the ones I restored I don't use high heat paint on the engines and never had issues. sometimes I use high heat flat black on new mufflers because I don't like the silver on the replacement ones Share this post Link to post Share on other sites
The Tuul Crib 7,332 #6 Posted December 2, 2018 (edited) I use regal red rustoleum . That seems to be the going paint and is closest to original that I have found. There are a lot of variations of the red and I seem to like them all! Duplicolor hi heat seems to be the best for the motor that I have used. Edited December 2, 2018 by The Tool Crib 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,369 #7 Posted December 3, 2018 4 hours ago, The Tool Crib said: Duplicolor hi heat seems to be the best for the motor that I have used. You mean like this... 3 Share this post Link to post Share on other sites
Stormin 9,975 #8 Posted December 13, 2018 When I rebuilt my C-121, (aka The Black Horse) I used BBQ paint on the engine. I'll be using the same on the C-125's engine. 1 Share this post Link to post Share on other sites
Herder 2,354 #9 Posted December 13, 2018 On 12/2/2018 at 3:52 PM, The Tool Crib said: I use regal red rustoleum . That seems to be the going paint and is closest to original that I have found. There are a lot of variations of the red and I seem to like them all! Duplicolor hi heat seems to be the best for the motor that I have used. I use the rustoleum regel red on the all of my engines and it holds up very well. I do find any type paint including heat paint will still burn off around the exhaust port area, the heat is to high. Share this post Link to post Share on other sites
The Tuul Crib 7,332 #10 Posted December 13, 2018 1 hour ago, Herder said: I use the rustoleum regel red on the all of my engines and it holds up very well. I do find any type paint including heat paint will still burn off around the exhaust port area, the heat is to high. Especially if you run the no ethanol blend which tends to burn hotter 1 Share this post Link to post Share on other sites
Jay Wellwood 28 #11 Posted December 14, 2018 On 12/13/2018 at 7:33 AM, Stormin said: When I rebuilt my C-121, (aka The Black Horse) I used BBQ paint on the engine. I'll be using the same on the C-125's engine. Seems like a natural color and type of paint selection for the engine. Red tractor - black hi temp motor paint. Good call. 1 Share this post Link to post Share on other sites
