Evil Archer 300 76 #1 Posted November 30, 2018 My tractor had been running fine, I had a change in the tone of the exhaust shut it down and will not start. The fuel pump is pumping gas,I have spark, There is compression. Any ideas where I should start. Share this post Link to post Share on other sites
skrusins 128 #2 Posted December 1, 2018 Spray some WD40 or Carb cleaner in the carb and see if it pops. That will narrow it down to dirty carb or bad gas. Share this post Link to post Share on other sites
953 nut 63,949 #3 Posted December 1, 2018 2 hours ago, Evil Archer 300 said: had a change in the tone of the exhaust shut it down and will not start. Can you tell us a little more about the change? Share this post Link to post Share on other sites
Evil Archer 300 76 #4 Posted December 25, 2018 I haven't been on in a while ( busy with Hunting ) I have done some investigating ,There is no compression, I removed the Head and both valves are moving the cylinder looks good no grooves or scratching. All I can figure is one of the valves is not seating. I'm not sure if it's worth rebuilding. Share this post Link to post Share on other sites
oldredrider 2,553 #5 Posted December 25, 2018 Kohlers are ALWAYS worth rebuilding. Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #6 Posted December 25, 2018 Valve job is easy Share this post Link to post Share on other sites
Tuneup 1,452 #7 Posted December 26, 2018 You already have the head off so pull the valve cover and check the clearances. Once that far, won't take long to run through a valve job. Done! Hunting is a priority and we understand Share this post Link to post Share on other sites
The Tuul Crib 7,340 #8 Posted December 26, 2018 23 hours ago, oldredrider said: Kohlers are ALWAYS worth rebuilding. Share this post Link to post Share on other sites
WH nut 553 #9 Posted December 29, 2018 You didnt say if the piston is moving Share this post Link to post Share on other sites
