dave647 27 #1 Posted November 30, 2018 what is the large(4"x6") opening in the rear fender under the seat for? was there a drop in tool tray for this opening? Share this post Link to post Share on other sites
Stormin 9,988 #2 Posted November 30, 2018 Good question. I'd like to know myself. I've one in the same place on my C-125. Though I think the fender is a replacement for an original plastic one. Share this post Link to post Share on other sites
peter lena 10,032 #3 Posted November 30, 2018 that's for basic operational check on shifter boot, wire routing and view points to look for problems . you can see the drive belt area the clutch linkage . I use it regularly to keep an eye on things. just a good access point , between that and the lower dash plate ,and shifter gate ,you can look inside at service areas. pete 1 1 Share this post Link to post Share on other sites
Lee1977 7,756 #4 Posted December 1, 2018 My guess is that the hole is used for location in the fender forming process. I would think that there are least three different stampings to complete the fender. 1 Share this post Link to post Share on other sites
cleat 9,296 #5 Posted December 1, 2018 With the hydro trans. You use this to access the hydro linkage. 1 1 Share this post Link to post Share on other sites
