giddyap 1,574 #1 Posted November 26, 2018 I would never put 60 pounds on my hitch in fear of cracking the tranny case. So I attached the yellow support on the toolbox under the seat and the weight hangs from it. The 1/2" threaded rod connects the hitch to the hanger so not only can I secure the load but I can also adjust the hitch. Adjusted just right, my hitch does not touch the bottom of the case and barely kisses the back. 60 pounds becomes weightless (on the hitch) 6 Share this post Link to post Share on other sites
lynnmor 8,154 #2 Posted November 26, 2018 I cracked a case and learned the hard way. I wouldn't be afraid to add a little weight back there, but no way would I add a lot, especially high up where the leverage would make things even worse. 1 Share this post Link to post Share on other sites
953 nut 62,639 #3 Posted November 26, 2018 Liquid filled tires will do a lot of good too. SIZE GALLONS Per Tire WEIGHT in POUNDS 16x6.50-8 2.0 21.4 18x7.00-8 3.0 32.1 18x8.50-8 3.4 36.4 18x9.50-8 4.0 42.8 23x8.50-12 5.5 58.9 23x10.50-12 6.8 72.8 6-12 3.6 38.5 2 Share this post Link to post Share on other sites
peter lena 9,521 #4 Posted November 26, 2018 thinking and reacting to it will keep your horse alive, good idea , Pete 1 Share this post Link to post Share on other sites
