Navig8r 132 #1 Posted November 25, 2018 I'm having trouble putting the pieces together on which pulley will fit... Know I have a 3/4" shaft with 5 1/2" original pulley.. OEM is crazy money, but not sure if some of the replacements I'm finding will take the 5/8" wide belt..... Anyone know what section width this belt would be (5L perhaps?) Was looking at this from TSC.... https://www.tractorsupply.com/tsc/product/phoenix-standard-a-b-type-3-4-steel-drive-pulley-5-in-od?cm_vc=-10005 I know its a 5" vs. 5 1/2"... wouldnt mind running just shy of full throttle if all else is good. Any help is greatly appreciated as is all the help I've already gotten trying to get this thing together! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,762 #2 Posted November 25, 2018 It says A/B type. Assuming that is the belt width A being 1/2" and B being 5/8". Most replacement pulleys will accept both belt widths. The narrower belt will give a slightly smaller effective diameter. Garry 1 Share this post Link to post Share on other sites
wallfish 18,630 #3 Posted November 25, 2018 You can also find cast pulleys of many sizes here. https://www.surpluscenter.com/Pulleys/Finished-Bore-Pulleys/?page_no=1&fq=ATR_Grooves:1&fq=ATR_Bore_Fractional:3/4\" Not sure the pic for 5.45" D is correct as a spoke pulley. I've ordered many different pulleys and they weren't spoke pulleys until the larger diameter around 8 inches. Not like it makes any difference anyway but... 1 Share this post Link to post Share on other sites
peter lena 9,479 #4 Posted November 25, 2018 you might also check your local BEARING DISTRIBUTOR , they specialize in belts, pulleys ,and bearing related problems. pete Share this post Link to post Share on other sites
AMC RULES 37,236 #5 Posted November 25, 2018 ...or, if you know the factory part number... our very own classifieds. 1 Share this post Link to post Share on other sites
Navig8r 132 #6 Posted November 25, 2018 4 minutes ago, AMC RULES said: ...or, if you know the factory part number... our very own classifieds. I saw this, but saw a post at the end that said these pulleys were no longer available, I guess I should message him..... Share this post Link to post Share on other sites
AMC RULES 37,236 #7 Posted November 25, 2018 Can't hurt to touch bases. Just discovered yesterday, another source for NOS original dealership parts here local to me too. Share this post Link to post Share on other sites
Navig8r 132 #8 Posted November 25, 2018 (edited) 4 minutes ago, AMC RULES said: Can't hurt to touch bases. Just discovered yesterday, another source for NOS original dealership parts here local to me too. Care to share that source? .... I'm not far from you... I'm in Gardiner, and travel Westchester daily, so I cover some ground.... Edited November 25, 2018 by Navig8r Share this post Link to post Share on other sites
AMC RULES 37,236 #9 Posted November 25, 2018 Sure, will send in a PM. 1 Share this post Link to post Share on other sites
