Dad520H 0 #1 Posted November 22, 2018 Hi! I'm an old Wheel Horse owner, but new here. I just bought a 1990 520H in really good condition. I have the mower deck, snowblade, and a cab. I've been looking for a snowblower and my friend gave me one that he had in his collection and thought might fit. The ID tag is gone but I can describe it. Short chute cable controlled. Rollers instead of skids. It does have the side extensions making it wide. I'm guessing it's around a 1970 model, possibly a 6-6214. Is it possible for this to fit my 520H? The FREE price is right! I would appreciate any and all help. I've been using this sight but never registered. You guys are great and very good at what you know! Thank you! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #2 Posted November 22, 2018 If it is a 6-6214 it should fit. Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced. Snowthrower rear frame has a 5/8" diameter round bar. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) 1976 model 6-6215 - This one - 1976 model 66-42ST01 - and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - This one 1978 model 86-42ST01 - and this one 1979 model 96-42ST01 - and this one plus 1980 may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use chute cable) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 2002-2007 model 79362 Garry 1 1 Share this post Link to post Share on other sites
rjg854 12,862 #3 Posted November 22, 2018 @Dad520H Does it have a threaded bolt that passes thru the frame or does it attach to the front attach-a-matic with a rod. Share this post Link to post Share on other sites
Ed Kennell 45,029 #4 Posted November 22, 2018 to the If it has the welded in round rod that hooks into the attach-a-matic, it will fit. If it has the long 3/8" bolt and two spacers that bolt to the tractors frame, it would require some modification. 1 Share this post Link to post Share on other sites
Dad520H 0 #7 Posted November 24, 2018 Thanks everyone. Yes, it is tach-a-matic, and all fits like a glove! This old blower needs a new paint job, but runs great. 5-8" Snow coming early Sunday morning. Probably wet, heavy. Just have to take her slow. Thanks again, everyone! Share this post Link to post Share on other sites
Dad520H 0 #8 Posted November 24, 2018 Another question: Has anyone ever tried to make a tall chute out of a a short chute, and is there really a greater advantage of one over the other? Thanks again! Share this post Link to post Share on other sites
Ed Kennell 45,029 #9 Posted November 24, 2018 I've had both and I never saw a lot of difference in their performance.. Both tend to clog in the wet heavy snow. For that , you need a two stage. I do like the worm gear chute rotator on the tall chute better than the cable drive on the short chute. 1 Share this post Link to post Share on other sites
Dad520H 0 #10 Posted November 24, 2018 Thanks, Ed. I had a tall chute on a John Deere 48" single stage. Would blow snow like a champ if it was "the perfect snow". Plugged up easy when wet, they all do. The gear drive chute definitely better. Share this post Link to post Share on other sites
