joskuk 67 #1 Posted November 16, 2018 This morning I started preparing the 416 for the snow storm we got tonight. I did an oil change with 10W-30 and swapped the deck for the plow. Everything was going so well, we got a lot more snow than expected and it was plowing great. On my second pass up the driveway the headlights started to flicker, and then a second later the headlights died. I looked at the voltage gauge and it showed 0, and the taillights were not working either. The engine however stayed running. I drove the tractor back up to the garage and shut it down. Took a look at obvious things like blown fuses, but the two 15A and 25A fuses looked good. I went to start the tractor back up but it won't start now either (with the key). I'm pretty confused about this one, if anyone has seen something like this before the help would be very appreciated. Still have half a driveway to plow I was thinking the ignition switch but you would think it wouldn't run at all then... 1 Share this post Link to post Share on other sites
lynnmor 8,628 #2 Posted November 16, 2018 1 hour ago, joskuk said: I was thinking the ignition switch but you would think it wouldn't run at all then... Could be the ignition switch, it all depends on which contacts failed. Of course a bad connection elsewhere is also possible, I suggest you download the demystification guide. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #3 Posted November 16, 2018 What is the model number of your tractor? Some 416's used a Kohler with battery ignition Some 416's used a Kohler with magneto ignition Some 416's used an Onan with battery ignition All wired differently Garry 1 Share this post Link to post Share on other sites
953 nut 64,127 #4 Posted November 16, 2018 5 hours ago, joskuk said: the headlights started to flicker, and then a second later the headlights died. I looked at the voltage gauge and it showed 0, and the taillights were not working either. 5 hours ago, joskuk said: fuses looked good. It sounds like you have some electrical connections that are not tight or are corroded. Share this post Link to post Share on other sites
dells68 7,499 #5 Posted November 16, 2018 My c125 did something similar. Tail lights came on when cranking, starter spun but wouldn’t engage. Turned out to be a bad ground between the battery and engine. 1 Share this post Link to post Share on other sites
Lost Pup 173 #6 Posted November 16, 2018 I had my 416H out as well clearing the snow. 10 minutes in I turned on the lights, lasted only a few minutes then went out. I flicked the switch a few times and the small switch handle just broke off. Points to the problem easy enough. Never had this type of switch break like that but it was a neglected machine from the PO. Share this post Link to post Share on other sites
joskuk 67 #7 Posted November 16, 2018 (edited) 4 hours ago, gwest_ca said: What is the model number of your tractor? Some 416's used a Kohler with battery ignition Some 416's used a Kohler with magneto ignition Some 416's used an Onan with battery ignition All wired differently Garry How could I forget? It's a 1987 with the Kohler magnum, so magneto ignition. 31-16K803. 2 hours ago, dells68 said: My c125 did something similar. Tail lights came on when cranking, starter spun but wouldn’t engage. Turned out to be a bad ground between the battery and engine. Thanks, I'll definitely take a look at that today. Edited November 16, 2018 by joskuk Share this post Link to post Share on other sites
peter lena 9,768 #8 Posted November 16, 2018 found grounding to be a regular issue, until I regularly went over all grounding points with a wire brush and dielectric grease .like 953 says , electrical basics are vital for operation, pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #9 Posted November 16, 2018 4 hours ago, joskuk said: Click on the picture first to see the notes on this file Garry 1 Share this post Link to post Share on other sites
joskuk 67 #10 Posted November 16, 2018 I checked the battery voltage today, I had to start the tractor and move it so I jumped the starter solenoid and it started up and ran fine. Just no power. I checked voltage while running and it was 12.2v at the battery, same as when it was off. So it's not charging. 6 hours ago, dells68 said: My c125 did something similar. Tail lights came on when cranking, starter spun but wouldn’t engage. Turned out to be a bad ground between the battery and engine. I tried to find a battery to engine ground cable, but the only one I see is the ground coming off the battery going to the hood stand. It looked good, but I'm going to go through all the electrical connections tonight with dielectric grease. We'll see how that goes. Share this post Link to post Share on other sites
roadapples 6,987 #11 Posted November 16, 2018 For all grounds I always use star washers and dielectric grease between wire end and ground. Never had a problem afterward. Don't be stingy with the grease... 3 Share this post Link to post Share on other sites
