snowhound 106 #1 Posted November 15, 2018 I've been told that my 518 starting issue could be a relay that is mounted near the battery. I have looked on the wiring schematic and can't find it does anyone have a part number for it? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,844 #2 Posted November 15, 2018 The only relay I see is the starter solenoid item 13 https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/31-18oe01-518-h-toro-518-h-garden-tractor-1988/electrical-system_1/ Garry 1 Share this post Link to post Share on other sites
953 nut 63,002 #3 Posted November 15, 2018 10 hours ago, snowhound said: starting issue could be a relay that is mounted near the battery. Before you start spending money on parts I would suggest you have the battery load tested and clean and tighten ALL electrical connections. Share this post Link to post Share on other sites
snowhound 106 #4 Posted November 17, 2018 Thanks for the replies I tested the solenoid and it was bad, replaced the solenoid and it fired right up. Share this post Link to post Share on other sites
