RDH 0 #1 Posted November 11, 2018 I am having trouble getting the linkage for the mower deck belt engage lever to clear the implement lift bar that goes between the frame vertical rails. I have had it in and out several times but the problem is the same. According to the parts manual it is installed correctly. I do recall when I disassembled the unit it did not bind. Can anyone tell me what I forgot to do? This is the 69 commando 7 with the vertical shaft engine setup. Only change is a newer engine. belts pulleys and such are new and were for this unit per parts list Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,509 #2 Posted November 11, 2018 Don't know if this will be enough the same to be of any help. Click on the picture and download from there. The only original manual I see. Garry Share this post Link to post Share on other sites
