DaleLicht 6 #1 Posted November 3, 2018 Hello Wheelhorse Fans, I have a 1984 C165, and the front rims are rusted and deteriorated to the point where I don't think they would hold air without tubes in them, and I am actually worries about the tire coming off the rim. I would like to replace them. Any retro fit info would be greatly appreciated since I can not locate the OEM, or Used rims for sale. Thank you, Dale Share this post Link to post Share on other sites
peter lena 9,886 #2 Posted November 3, 2018 just looking around and spotted this https://www.ebay.com/itm/1978-WHEEL-HORSE-C-161-8-SPEED-TRACTOR-Front-Wheels-Rims-With-16x6-5-8-Tires/323443253518?hash=item4b4eb8610e:g:r1wAAOSwHUlbmVlS could be more than you want , but then these wheels are complete. you can take it from there , and find what you want , good luck ,pete 1 1 Share this post Link to post Share on other sites
DaleLicht 6 #3 Posted November 3, 2018 Thanks Pete, I guess didn't look hard enough. I will follow up and close this thread, Thanks again, Dale Share this post Link to post Share on other sites
DaleLicht 6 #4 Posted November 3, 2018 So after looking a little more thoroughly, the part number I am looking for is #105882. The wheels referenced by Pete, are incorrect. I could not find any on Ebay and it is a discontinued. Saw nothing in the classifieds section either. Any info is appreciated. Thank you Share this post Link to post Share on other sites
oliver2-44 11,482 #5 Posted November 3, 2018 Contact Lin on at A-Z tractor in the vendor section 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #6 Posted November 3, 2018 I found a store here in Germany, they sell brand new Rims. also with Inch Ballbearings, i just don't know if they send to US, but a question cost nothing but a e-mail http://www.radundrolle.de/seiten/Felgen/Stahlfelgen/Kugelllager-Felge_450Ax6.htm the Item No: 253230WZ575 KuLa 3/4 Zoll (19,05mm) 75mm 35,2x19,05x12,5mm 26,90 € Seems exactly what you looking for. It was a Ballbearing Rim with 3/4" diameter for the Axle. this Rim is released for 300 Kilos thats about 660 pounds 2 1 Share this post Link to post Share on other sites
Elkskin's mower junkyard 1,117 #7 Posted November 3, 2018 1 hour ago, DaleLicht said: So after looking a little more thoroughly, the part number I am looking for is #105882. The wheels referenced by Pete, are incorrect. I could not find any on Ebay and it is a discontinued. Saw nothing in the classifieds section either. Any info is appreciated. Thank you They would still work. Just different design probably 1 1 Share this post Link to post Share on other sites
peter lena 9,886 #8 Posted November 3, 2018 any time I get a chance to buy wheels , I get them , a bearing change, clean up , Navajo white paint , and fluid film to mount tires , that also prevents rust issues in rims. I just like the old school look of a 8" front wheel, keep it simple , pete 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,302 #9 Posted November 4, 2018 9 hours ago, DaleLicht said: Saw nothing in the classifieds section either. Can't hurt to post in our "Wanted" section. Sometimes it's easier to buy an entire tractor just for parts. For less than a pair of new front rims I bought today a C121 that was previously dismantled. Came with everything including two Kohler 12's, two 8 speed granny's with hubs, a pair of rear rims with tires and piles of other items...and of course front rims ( sorry, not for sale). Just another way to score a set of rims 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,438 #10 Posted November 4, 2018 9 hours ago, Sparky said: ...two 8 speed granny's with hubs, Couldn't find an automatic Granny? My grannies make better cookies when they are automatics...with or without hubs... 18 hours ago, oliver2-44 said: Contact A-Z tractor in the vendor section 1 2 Share this post Link to post Share on other sites
pacer 3,180 #11 Posted November 4, 2018 Probably many rims will interchange......from what I've found the axle length is pretty much the determining factor - IIRC falls in the 3 to 4" lengths. A couple time I have used a rim that was a 1/4-1/2" shorter and used a spacer to make up the difference. But unless they are REALLY bad I just put tubes in. Share this post Link to post Share on other sites
Sparky-(Admin) 25,302 #12 Posted November 4, 2018 1 hour ago, SylvanLakeWH said: Couldn't find an automatic Granny? My grannies make better cookies when they are automatics...with or without hubs... Haha! Late night posting and a real finicky spell check on my I-pad strikes again! 1 1 1 Share this post Link to post Share on other sites
DaleLicht 6 #13 Posted November 10, 2018 Thanks to everyone for your help. I was able to purchase a used wheel from A-Z Tractor. 2 Share this post Link to post Share on other sites
