Dan693 510 #1 Posted October 29, 2018 Thought I should get a little advise from the elders.....Onan 14 HP single that exhausts out of the bottom of the head. I'm scrapping the old can type muffler and fabbing a new header to let it flow better. The issue is some oil is collecting in the old muffler. Not a ton but enough to make it smoke some on startup. It seems to clear out after running for a minute.. My feeling is worn rings....it has about 600 hrs on it but not worked hard.....only mowing. Not sure how valves would cause this. Since I have the hood and muffler off I'm thinking maybe hone the cylinder and install a new set of rings. Any thoughts on this issue and any products I could add to the oil to maybe free up the current rings? I probably could live with it but I'm just not built that way lol. Thanks in advance! Share this post Link to post Share on other sites
Tractorhead 9,214 #3 Posted October 29, 2018 How about the Intakevalve Seal? Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted October 29, 2018 I'm with Paul on this one sounds to me like valve guides . Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted October 29, 2018 Just now, The Tool Crib said: I'm with Howie on this one sounds to me like valve guides . Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #6 Posted October 29, 2018 Marvel Mystery Oil it does help. Share this post Link to post Share on other sites
MalMac 1,333 #7 Posted November 2, 2018 Are you sure you got a Onan there. If it’s a 14hp in a Wheel Horse it’s a Kohler. I ageee with the rest if your getting that much oil. Also could be a crank vent. When the crankcase builds up pressure it has to relieve it self somewhere. With a Kohler it can come from anywhere. Share this post Link to post Share on other sites
WHX?? 52,896 #8 Posted November 3, 2018 He's got a 244H Mal so yes a EV-145 Onan vertical. Not sure if there are guide seals, check the manual. Guides could weeping by a little tho. Share this post Link to post Share on other sites
