Justice77 163 #1 Posted October 29, 2018 (edited) I got tired of freeing a stuck intake valve on the unknown origin 5 hp Briggs so for a $100 I got a 212 cc Predator in there now. had to raise tin 1" in order to get 1/8" clearance between engine and tin above it, + 1/8" between steering shaft and intake (on one side) and exhaust (on the other side) and ignition wire (just under shaft), by moving bulkhead that supports steering shaft about 1" forward. Then had to take steering pinion / rack assembly apart, tweak, lube and reassemble then adjust a few times to get it working smooth. Absolutely love this rig now. Depending on rpm and how I release clutch, it will do wheelies now. No plans for further mods besides finding a smallish York rake to fit, and / or getting an old snow blade that I have attached. Edit - not sure if I mentioned before but I did drain and 2x flush the goo out of trans and added new gear oil. Edited October 29, 2018 by Justice77 words 9 Share this post Link to post Share on other sites
oliver2-44 11,215 #2 Posted October 29, 2018 Very nice, clay you didn’t cut the hood. The tractor has a nice patina. 2 Share this post Link to post Share on other sites
WHNJ701 4,169 #3 Posted October 29, 2018 Nice tractor hopefully you can find period correct engine for it, sadly alot of good tractors get cut up and hack jobs to stuff these engines in Share this post Link to post Share on other sites
peter lena 9,770 #4 Posted October 29, 2018 good swap on that, you will probably have more fun with that , leaving it in that set up. on that rear end drain, I have found using, atf fluid to be a very good flush agent. the 312-8 I picked up , responded very well, to its trans clean out, good luck , pete Share this post Link to post Share on other sites
Justice77 163 #5 Posted October 29, 2018 3 hours ago, oliver2-44 said: Very nice, clay you didn’t cut the hood. The tractor has a nice patina. Yea.... no need to or desire to cut the perfect hood. I love the patina as well. Wouldn't dream of painting this. 1 Share this post Link to post Share on other sites
Justice77 163 #6 Posted October 29, 2018 2 hours ago, jabelman said: Nice tractor hopefully you can find period correct engine for it, sadly alot of good tractors get cut up and hack jobs to stuff these engines in I suppose period correct engine would be nice but I'm really liking the reliability and power. Share this post Link to post Share on other sites
Justice77 163 #7 Posted October 29, 2018 1 hour ago, peter lena said: good swap on that, you will probably have more fun with that , leaving it in that set up. on that rear end drain, I have found using, atf fluid to be a very good flush agent. the 312-8 I picked up , responded very well, to its trans clean out, good luck , pete I did use atf to flush. Took a couple times to get it properly clean. Share this post Link to post Share on other sites
Justice77 163 #8 Posted October 29, 2018 I did have a linkage designed out of 1/4" x 1" plywood slats to figure out using the existing ratcheted arch and handle to lift the plow prior to engine swap. Now that new engine took up more forward space I'll have to redesign a bit, then fab from steel. 1 Share this post Link to post Share on other sites
ebinmaine 77,360 #9 Posted October 29, 2018 I like it Joe. I too, am impressed with the fact that you engineered a way to fit the engine in instead of Smashing the outside metal around. Well done sir. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #10 Posted October 29, 2018 Yep this is a case where the 20th century meets the21st!! Will be waiting for more ! Very nice Share this post Link to post Share on other sites
Chris G 3,369 #11 Posted October 29, 2018 Nice job and I'm also glad to see ya didn't have to cut it up Share this post Link to post Share on other sites
Pullstart 68,887 #12 Posted October 30, 2018 19 hours ago, Justice77 said: Yea.... no need to or desire to cut the perfect hood. I love the patina as well. Wouldn't dream of painting this. Looks like some Christmas’ed it up a bit in the rear though? Maybe thT’s something that could stand a little wet sanding? Share this post Link to post Share on other sites
Justice77 163 #13 Posted October 30, 2018 21 minutes ago, pullstart said: Looks like some Christmas’ed it up a bit in the rear though? Maybe thT’s something that could stand a little wet sanding? P.O. mentioned that they painted fenders a long time ago. thT's?? Is that a mis-spell or abbreviation I don't get? Share this post Link to post Share on other sites
Pullstart 68,887 #14 Posted October 30, 2018 Auto correct, or something maybe... “that’s”. Share this post Link to post Share on other sites
